Author Topic: Setting Lineweight within layer creation LISP  (Read 1530 times)
npstewart87
  • Mosquito
« on: March 29, 2020, 02:09:02 PM »
Good afternoon,
I have several LISP routines created by a former employee and im looking for help to edit one of them. Please note that I have extremely limited ability to code much of anything. This particular routine is to create a revision cloud layer of any name, sets the color, etc. The problem is that the lineweight is far to light and I would like to darken it up so its easier to read. Ideally I would like the lineweight to be "0.010".
The text of the routine is below.
  1. (defun D_Cloud_dcl_setup ( / )
  2.   (if (= REV nil) (setq REV "1"))
  3.
  4.   (setq D_Cloud_dcl_id (load_dialog (strcat PTH8 "D_Cloud.dcl")))
  5.   (if (not (new_dialog "D_Cloud" D_Cloud_dcl_id))
  6.     (exit))
  7.
  8.   (set_tile "rev_no" REV)
  9.   (action_tile "rev_no" "(setq REV $value)")
  10.
  11.   (action_tile "accept" "(done_dialog)")
  12.   (action_tile "cancel" "(setq CANCEL_PROG \"1\")")
  13.
  14.   (unload_dialog D_Cloud_dcl_id)
  15. );end
  16.
  17. ;;; ************************** Layer for cloud Cloud Program ****************
  18. (defun D_Cloud_Layer ( / )
  19.
  20.   (setq L_NAME (strcat "G-CLOUD-" REV)
  21.         L_TRI (strcat L_NAME "-TRI"))
  22.
  23.   (command "-LAYER" "M" L_NAME "C" "100" "" "LT" "CONTINUOUS" "" "")
  24. );end
  25.
  26. ;;; ************************** Draw Program *********************************
  27. (defun D_Cloud_R_Draw ( / )
  28.   (setvar "OSMODE" 0)
  29.
  30.   (setq LOWER_PT (getpoint "\nPick cloud lower rectangle point: <None> " ))
  31.   (initget 32)
  32.   (setq UPPER_PT (getcorner LOWER_PT "\nPick cloud upper rectangle point: <None> " ))
  33.   (setq ARC_DIST (* 0.2 (getvar "dimscale" )))        ;;set & adjust arc size
  34.
  35.   (command "rectangle" "c" 0 0 "e" 0 "f" 0 "t" 0 "w" 0 LOWER_PT UPPER_PT)
  36.
  37.   (command "_revcloud" "s" "N" "a" ARC_DIST ARC_DIST "o" "last" "N")
  38.
  39.   (princ "\nClosing cloud...")
  40.
  41.   (command "-LAYER" "M" L_TRI "C" "161" "" "LT" "CONTINUOUS" "" "")
  42.   (setvar "ATTDIA" 0)
  43.   (setvar "ATTREQ" 1)
  44.   (prompt "\nInsertion point: <None> ")
  45.   (command "_INSERT" (strcat pth1 "Text_Sym_Tri") "SCALE" SB "ROTATE" 0 PAUSE)
  46.   (command REV "")
  47. );end
  48.
  49.
  50. ;;; ************************** Main Program *********************************
  51. (defun C:D_Cloud_R ( / LOWER_PT UPPER_PT ARC_DIST )
  52.   (var_in)
  53.   (if (= SB nil)
  54.     (Alert_Msg)
  55.     (progn
  56.       (D_Cloud_dcl_setup)
  57.       (if (/= CANCEL_PROG "1")(D_Cloud_Layer))
  58.       (if (/= CANCEL_PROG "1")(D_Cloud_R_Draw))
  59.     );end_progn
  60.   );end_if
  61.   (var_out)
  62. );end
EDIT (John): Added code tags.
« Last Edit: March 30, 2020, 12:13:33 PM by John Kaul (Se7en) »
Dlanor
Re: Setting Lineweight within layer creation LISP
« Reply #1 on: March 29, 2020, 06:24:25 PM »
Try this. I've commented the lines with the items added to both layers. The lineweight has been set to 0.09mm which was the nearest to your figure of 0.01
  3.
  6.     (exit))
  7.
  10.
  13.
  15. );end
  16.
  19.
  22.
  23.   (command "-LAYER" "M" L_NAME "C" "100" "" "LT" "CONTINUOUS" "" "LW" "0.09" "" "")  ; added  "LW" "0.09" ""
  24. );end
  25.
  29.
  31.   (initget 32)
  34.
  36.
  38.
  40.
  41.   (command "-LAYER" "M" L_TRI "C" "161" "" "LT" "CONTINUOUS" "" "LW" "0.09" "" "") ; added  "LW" "0.09" ""
  47. );end
  48.
  49.
  52.   (var_in)
  53.   (if (= SB nil)
  54.     (Alert_Msg)
  55.     (progn
  59.     );end_progn
  60.   );end_if
  61.   (var_out)
  62. );end
npstewart87
  • Mosquito
« Reply #2 on: March 30, 2020, 11:49:10 AM »
Thanks so much for the reply!
I just went to try this and it says "Error: extra right paren on input"
Dlanor
« Reply #3 on: March 30, 2020, 07:59:15 PM »
I've rechecked the posted code and there is no extra right parentesis. perhaps in one of the referenced sub routines
(var_in), (Alert_Msg) or (var_out)
You may also have missed the first opening paren when copying. I have attached a copy of the file in case this was the problem.
