Author Topic: casting xData.value to enum head scratcher  (Read 1837 times)
« on: March 23, 2020, 04:41:56 PM »
It compiles
It seems 100% legit
It crashes without raising an exception
Documentation says TypedValue 1070 is Int32
I can Convert.ToInt32(tv.Value) without issue and then cast to an enum
enum is Int32
It's a head scratcher for me for sure
(code abbreviated for clarity)
Code - C#: [Select]
  1. //get the stored enum status data from the object
  2. statusEnum st = statusEnum.none; //=0
  3. foreach (TypedValue tv in obj.ResultBuffer)
  4. {
  5.     if (tv.TypeCode == 1070)
  6.         st = (statusEnum)tv.Value;
  7. }
MickD
Re: casting xData.value to enum head scratcher
« Reply #1 on: March 23, 2020, 05:09:17 PM »
have you looked into DxfCodes? This is the enumeration for TypedCodes
maybe you can try ((DxfCode)tv.TypedCode== 1070) as your condition?
btw the doc's show all codes being a short or Int16  therefore DxfCode.ExtendedDataInteger16 = 1070 (or 0x42e)
hth
« Last Edit: March 23, 2020, 05:12:19 PM by MickD »
- John Carmack
- J.R.R. Tolkien
Hanauer
  • Mosquito
« Reply #2 on: March 23, 2020, 06:08:22 PM »
Have you looked here: https://adndevblog.typepad.com/autocad/2012/12/store-and-retrieve-enum-values-in-a-resbuf-using-net.html
Try change:
with
st = (statusEnum)Enum.ToObject(typeof(statusEnum), tv.Value);
or with
use DxfCode.ExtendedDataInteger32 (1071).
Here's what I use:
GhAcStatusEnum st = GhAcStatusEnum.Existente;
if (tv.TypeCode == (int)DxfCode.ExtendedDataInteger16)
    // Only works if the enum value in
    // the Xdata was stored as ExtendedDataInteger32 (1071)
    // GhAcStatusEnum st = (GhAcStatusEnum)tv.Value;
    // Works in both the cases
    // if the enum value in the Xdata was
    // stored as ExtendedDataInteger16 (1070)
    // or as ExtendedDataInteger32 (1071)
    st = (GhAcStatusEnum)Enum.ToObject(typeof(GhAcStatusEnum), tv.Value);
« Last Edit: March 23, 2020, 07:05:50 PM by Hanauer »
« Reply #3 on: March 23, 2020, 07:33:58 PM »
Ah .. so perhaps I'll give the 1071 group a try. Essentially I need to store an enum in xdata and retrieve it at a later date. enum is Int32 so that could possibly be the issue. I'll give it a shot and see what happens.
