Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
annotative to Non-annotative lisp
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: annotative to Non-annotative lisp (Read 1585 times)
PM
Guest
on:
March 21, 2020, 07:47:51 PM »
Hi. Can any one have a lisp to convert all annotative (blocks,linew,text,mtext,dimensions .....everything) to Non-annotative.
Logged
PM
Guest
Re: annotative to Non-annotative lisp
Reply #1 on:
March 23, 2020, 01:56:59 PM »
any ideas?
Logged
Needs a day job
Reply #2 on:
March 23, 2020, 03:14:44 PM »
Don't have time to code anything up, but look at XData.
Example from text (when annotative)
Code - Lisp:
[Select]
3
"AcadAnnotative"
1000
"AnnotativeData"
1002
1070
1
1070
1
1002
Example from text (when annotative is turned off)
Code - Lisp:
[Select]
3
"AcadAnnotative"
1000
"AnnotativeData"
1002
1070
1
1070
0
1002
Logged
PM
Guest
Reply #3 on:
March 29, 2020, 09:41:31 AM »
Yes for text i use this code but for all blocks , dimensions , linetypes .....alll ?
Code - Auto/Visual Lisp:
[Select]
defun
c:test
ss
if
setq
ss
ssget
"_X"
0
"TEXT,MTEXT"
command
"_.change"
ss
"_P"
"_A"
"_No"
princ
Logged
Needs a day job
Reply #4 on:
March 31, 2020, 03:15:34 PM »
If you want to change everything, then why not select everything in the ssget call. (ssget "x")) then you can pass what is returned to the change command. This might work for you, as I don't use annotative objects and I don't see them very often I'm not sure how well the idea will work.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
