Author Topic: [original works] adds GOTO instruction to AutoLisp language  (Read 12450 times)
baitang36
Re: [original works] adds GOTO instruction to AutoLisp language
« Reply #15 on: March 23, 2020, 10:20:58 PM »
Why do you say there is no GOTO you can use defun statements, I wrote a bubble sort that required dual defuns for the testing part and looping through the data set. Took a BASIC version and rewrote in lisp.
Ps here is my GOTO Autocad command.
thank you
You don't see what I mean. My GOTO is executed in the middle of one LSP function to the middle of another.
d2010
« Reply #16 on: March 24, 2020, 01:35:39 PM »
RE:Why do you say there is no GOTO you can use defun statements, I wrote a bubble sort that required dual defuns for the testing part and looping through the data set. Took a BASIC version and rewrote in lisp.
 :whistling:
Even today i keep this Qsort.lisp(after 25years). I think is very good-source. You can replace Bsort.Lsp with qsort.lsp
;Lisp2C
;AutoLISP to C (ADS) Translator User's Manual, Version 2.9, 1st revision
;(C) 1993, 1995 BASIC d.o.o Jesenkova 5, 61000 Ljubljana, Slovenia
;Tel: +386 1 314 069Fax: +386 1 318 211 e-mail: Jure Spiler jure @basic.si Joze Marincek
joze.marincek@mat.uni-lj.si CompuServe: [70541,1765]
;;implementat la (_lspfn_list_qsort)
(defun Qsort (lst / x l e g)
  (if lst
    (setq x (nth (/ (length lst) 2) lst)
          l nil e nil g nil)
    (while (not (null lst))
      (cond ((= (car lst) x) (setq e (cons x e)))
            ((< (car lst) x) (setq l (cons (car lst) l)))
            (t (setq g (cons (car lst) g)))
      (setq lst (cdr lst))
    (setq l (Qsort l)
          g (Qsort g))
    (append l e g)
   nil
kozmos
« Reply #17 on: March 27, 2020, 02:22:30 AM »
Fas to LSP program is a commercial software written by my friend. It can be converted almost perfectly, and most of the LSP generated can be loaded and run normally. He sells the software for 200 dollars. You can provide an fas file and I will decompile it for you to see
a crack software can claim itself as "commecial" software! shame
KozMos Inc.
baitang36
« Reply #18 on: March 27, 2020, 04:14:19 AM »
Crack usually means to modify, the software just translates, it doesn't change the content of the program
baitang36
« Reply #19 on: March 27, 2020, 04:16:46 AM »
This approach has become a tool. See     http://bbs.mjtd.com/thread-181151-1-1.html
baitang36
« Reply #20 on: March 27, 2020, 04:19:26 AM »
Coder
« Reply #21 on: March 27, 2020, 04:35:06 AM »
Agree with you.
Crack means that you are violating people's rights, in other words crackers = hackers = thieves ( burglars ).
I don't know why the admins allow you to post such threads in this esteemed and professional forum that is full of great people !
baitang36
« Reply #22 on: March 27, 2020, 07:31:50 AM »
Agree with you.
You don't understand me at all. I study conservation, not destruction. It is true that decompilation exists, and I want it to fail!
baitang36
« Reply #23 on: March 27, 2020, 07:46:05 AM »
According to the law, in order to learn and study the design ideas and principles contained in the software, users who use the software by means of installation, display, transmission, storage, etc., do not need to obtain the license of the software copyright owner, and do not need to pay compensation to the owner
« Reply #24 on: March 27, 2020, 08:38:50 AM »
x 2
Citation needed.
« Reply #25 on: March 27, 2020, 08:42:20 AM »
Ignoring the fact that decompilers exist will not make them go away. baltang36 is posting methods to improve compilations through the use of better programming methods and information. Meaning: use the knowledge (s)he is posting to improve your programs/methods/etc. so your compiled programs are harder to decompile.
« Reply #26 on: March 27, 2020, 08:50:05 AM »
I’m going to break into your house. I will lift some property while I’m there but worry not - I’m doing research - I will share with others how I was able to breach your security. In the end your house - and your friend’s houses - will be much safer - the property I lifted was merely an education fee.
« Reply #27 on: March 27, 2020, 09:10:59 AM »
If I had better locks then you couldn't.  ...Around and around we go.
I agree that people should be nice too--who wouldn't--but I don't ignore that there are bad people. If I used a stick as a door lock to my house; who should I then be angry at if my house gets broken into?
« Reply #28 on: March 27, 2020, 09:40:37 AM »
Rationalizing burglary is _______ ______.
« Reply #29 on: March 27, 2020, 09:59:34 AM »
Acknowledging that burglary exists, or studying how a lock works, or wanting a better lock in general is ‘rationalizing burglary’? Don’t be absurd.
I don’t agree with compiling lisp code but I don’t begrudge the people that want to protect their IP if they feel it’s necessary.
