Author Topic: textbox  (Read 3121 times)
jtoverka
textbox
« on: March 18, 2020, 08:39:57 PM »
So autoLisp has the textbox command
(textbox elist)Does anyone have the visual lisp equivalent? I would like to be able to use objectDBX. It won't work if I have different textstyle settings in my current drawing compared to the drawing I am trying use this command on.
Re: textbox
« Reply #1 on: March 18, 2020, 09:26:36 PM »
Thinking out loud ...
1. You can use textbox in objectdbx tho the same restrictions (e.g. style) would apply.
2. Is there an issue defining a textstyle that sports the properties you want? Could be nuked when you're done with it.
3. You could use the getboundingbox method if there's an actual text/mtext/attrib/attdef object to examine (textstring cannot be null).
4. You can create a junk object dbx doc and use / discard to suit.
cadanalyst@gmail.com • http://cadanalyst.slack.com • http://linkedin.com/in/cadanalyst
jtoverka
Re: textbox
« Reply #2 on: March 18, 2020, 09:42:57 PM »
I am considering using this if all else fails.
I just tried doing number 3. I can't get it to work.
((lambda ( / document blockName textSize offset2D pItem_lay polygonFit polygonGap polygonDiameter)
  ;; variables for debugging
  (setq document (vla-get-activeDocument (vlax-get-acad-object)))
  (setq blockName "PNL100")
  (setq textSize "0.25")
  (setq offset2D '(0 0))
  (setq PITEM_LAY "PITEM")
  (setq PBAL_LAY "PBAL")
  (setq polygonFit "1")
  (setq polygonGap "0.1")
  (setq polygonDiameter "0.625")
  ;; snippet below
  ; Create WD textstyle if one does not exist
  ( (lambda (document / textStyles textStyle found)
      (setq textStyles (vla-get-textStyles document))
      (setq found (vl-catch-all-apply 'vla-item (list textStyles "WD")))
      (if (vl-catch-all-error-p found)
          (setq textStyle (vla-add textStyles "WD"))
          (vla-put-fontFile textStyle "sanss___.ttf")
          (vla-put-LastHeight textStyle 0.125)
          (vla-put-Width textStyle 1.0)
    document
  ; Create pBal_lay if one does not exist
  ( (lambda (document pBal_lay / layers layer found)
      (setq layers (vla-get-layers document))
      (setq found (vl-catch-all-apply 'vla-item (list layers pBal_lay)))
          (setq layer (vla-add layers pBal_lay))
    document pBal_lay
  ; Create pItem_lay if one does not exist
  ( (lambda (document pItem_Lay / layers layer found)
      (setq found (vl-catch-all-apply 'vla-item (list layers pItem_Lay)))
          (setq layer (vla-add layers pItem_Lay))
    document pItem_Lay
  (setq blocks (vla-get-blocks document))
  (setq block (vla-add blocks (vlax-3d-point 0 0 0) blockName))
  (vlax-for object block
    (vla-Delete object)
  (setq
    attributeObject
    (vla-addAttribute
      block           ; object
      (atof textSize) ; attheight
      0               ; attMode
      ""              ; attPrompt
      (vlax-3d-point  ; insertionPoint
        (reverse (cons 0.0 (reverse offset2D)))
      "B_ITEM"        ; attTag
      "AA"            ; attValue
  (vla-put-Alignment   attributeObject acAlignmentMiddle)
  (vla-put-Layer       attributeObject PITEM_LAY)
  (vla-put-StyleName   attributeObject "WD")
  (vla-put-ScaleFactor attributeObject 0.8)
  (if (wcmatch polygonFit "1")
      (vla-GetBoundingBox attributeObject 'minExt 'maxExt)
      (setq minExt (vlax->list minExt))
      (setq maxExt (vlax->list maxExt))
      (setq center (mapcar '/ (mapcar '+ minExt maxExt) '(2 2 2)))
      (setq gap (atof polygonGap))
      (setq radius
        (distance
          (mapcar '+
            center
            (rotatePoint
              center
              (list gap 0 0)
              (angle
                center
                minExt
      (setq origin2D '(0 0))
      (setq diameter (atof polygonDiameter))
      (setq radius (/ diameter 2))
Re: textbox
« Reply #3 on: March 18, 2020, 10:18:06 PM »
I’m on my iPad so no can test code. However, I use getboundingbox in objectdbx frequently -  successfully - to wit - have quasi ssget crossing type functions based on same for use in objectdbx.
Do note that objects with the textstring property can’t have empty ("") strings - test for said condition, temporarily assigning a standard string (I use "-" IIRC) before a getboundingbox call, then restoring "" afterward in order to determine a "standard minimum bounding box size for null text items".
Long day pounding code - kinda burnt out - hope that made sense - cheers.
Re: textbox
« Reply #4 on: March 20, 2020, 09:17:36 AM »
Not sure this will be of any use but you can take a look at this old routine.http://www.theswamp.org/index.php?topic=7003.0
I've reached the age where the happy hour is a nap. (°Ώ°)
jtoverka
Re: textbox
« Reply #5 on: March 22, 2020, 01:39:25 AM »
This was a lot harder than it should have been. For some reason I can't make a block attribute definition and store it into a variable and find the bounding box on that variable. However, if I create the block, go in block editor and get the object from the attribute definition, the GetBoundingBox method will work. I looked into it, and the handle produced from creating the attdef is not the same as the one where I select the attdef. I don't know what is going on there, but I have found a work around.
; Name: J. Overkamp
; Date: 03/21/2020
; Parameters:
;   textObject - VLA-OBJECT attribute/attributeReference
; Return:
;   bounding box
(defun JO:textboxODBX (textObject / *error* JO:findFontFile acadObject activeDocument document objectName
                                 textHeight textString textRotation textWidth textObliqueAngle textStyleName textAlignment
                                 textHorizontalAlignment textVerticalAlignment documentTextStyles activeDocumentTextStyles documentTextStyle
                                 i newTextStyle newTextStyleName complete boundingBox textInsertionPoint
  (defun *error* (msg / )
    (acet-ui-progress-done)
    (if (= 'VLA-OBJECT (type newTextStyle))
      (vla-delete newTextStyle)
    (princ "Error: ")
    (princ msg)
  (defun JO:findFontFile (font / filePath path files)
    (setq filePath (findfile font))
    (if filePath
        filePath
        (setq path (strcat (getenv "windir") "\\Fonts\\"))
        (setq files (vl-directory-files path "*"))
        (if (member font files)
          (strcat path font)
    (and
      (setq objectName       (vla-get-objectName   textObject))
      (wcmatch objectName "AcDbAttributeReference,AcDbAttributeDefinition,AcDbAttribute")
      (setq acadObject       (vlax-get-acad-object))
      (setq activeDocument   (vla-get-activeDocument acadObject))
      (setq document         (vla-get-document     textObject))
      (setq textHeight       (vla-get-Height       textObject))
      (setq textString       (vla-get-TextString   textObject))
      (setq textRotation     (vla-get-Rotation     textObject))
      (setq textWidth        (vla-get-ScaleFactor  textObject))
      (setq textObliqueAngle (vla-get-ObliqueAngle textObject))
      (setq textStyleName    (vla-get-StyleName    textObject))
      (setq textAlignment    (vla-get-alignment    textObject))
        ((= textAlignment acAlignmentLeft)
          (setq textHorizontalAlignment 0)
          (setq textVerticalAlignment   0)
        ((= textAlignment acAlignmentCenter)
          (setq textHorizontalAlignment 1)
        ((= textAlignment acAlignmentRight)
          (setq textHorizontalAlignment 2)
        ((= textAlignment acAlignmentAligned)
          (setq textHorizontalAlignment 3)
        ((= textAlignment acAlignmentMiddle)
          (setq textHorizontalAlignment 4)
        ((= textAlignment acAlignmentFit)
          (setq textHorizontalAlignment 5)
        ((= textAlignment acAlignmentTopLeft)
          (setq textVerticalAlignment   3)
        ((= textAlignment acAlignmentTopCenter)
        ((= textAlignment acAlignmentTopRight)
        ((= textAlignment acAlignmentMiddleLeft)
          (setq textVerticalAlignment   2)
        ((= textAlignment acAlignmentMiddleCenter)
        ((= textAlignment acAlignmentMiddleRight)
        ((= textAlignment acAlignmentBottomLeft)
          (setq textVerticalAlignment   1)
        ((= textAlignment acAlignmentBottomCenter)
        ((= textAlignment acAlignmentBottomRight)
      (setq documentTextStyles       (vla-get-TextStyles document))
      (setq activeDocumentTextStyles (vla-get-TextStyles activeDocument))
      (setq documentTextStyle  (vla-Item documentTextStyles textStyleName))
      (setq i 0)
      (while
        (and
          (setq i (1+ i))
          (not complete)
        (setq newTextStyleName (strcat textStyleName (itoa i)))
          (and
            (vl-catch-all-error-p (vl-catch-all-apply 'vla-item (list activeDocumentTextStyles newTextStyleName)))
            (vl-catch-all-error-p (vl-catch-all-apply 'vla-item (list documentTextStyles       newTextStyleName)))
            (setq newTextStyle (vla-add activeDocumentTextStyles newTextStyleName))
            (setq complete T)
      (setq bigFontFile
        (JO:findFontFile (vla-get-BigFontFile documentTextStyle))
      (if bigFontFile
        (vla-put-BigFontFile      newTextStyle bigFontFile)
      (setq fontFile
        (JO:findFontFile (vla-get-FontFile    documentTextStyle))
      (if fontFile
        (vla-put-FontFile         newTextStyle fontFile)
      (vla-put-Height             newTextStyle (vla-get-Height             documentTextStyle))
      (vla-put-LastHeight         newTextStyle (vla-get-LastHeight         documentTextStyle))
      (vla-put-ObliqueAngle       newTextStyle (vla-get-ObliqueAngle       documentTextStyle))
      (vla-put-TextGenerationFlag newTextStyle (vla-get-TextGenerationFlag documentTextStyle))
      (vla-put-Width              newTextStyle (vla-get-Width              documentTextStyle))
        ((wcmatch objectName "AcDbAttributeReference,AcDbAttributeDefinition,AcDbAttribute")
          (setq boundingBox
            (textbox
              (list
                (cons 40 textHeight)
                (cons 1  textString)
                (cons 50 textRotation)
                (cons 41 textWidth)
                (cons 51 textObliqueAngle)
                (cons 7  newTextStyleName)
                (cons 72 textHorizontalAlignment)
                (cons 74 textVerticalAlignment)
          (if (not boundingBox)
              (setq textInsertionPoint (vla-get-insertionPoint textObject))
              (setq boundingBox (list textInsertionPoint textInsertionPoint))
  boundingBox
Re: textbox
« Reply #6 on: March 22, 2020, 02:59:09 PM »
Here's the results of a quick test I just ran.  I created a block def hosting 2 attdefs, one based on a shx font (romans), the other on a true type font (arial). I created an instance and then queried the attribs by the textbox function and the getboundingbox method, in the active drawing, via ODBX in a drawing that had both styles defined, and via ODBX in another drawing that had neither style defined. My observations:
Notes:
1. Z coord dumped for clarity
2. Normalized means distilled to delta x, delta y.
/FWIW
jtoverka
Re: textbox
« Reply #7 on: March 22, 2020, 04:30:41 PM »
Was this block created and saved in a drawing prior to running the textbox vs getBoundingBox methods? I can use getBoundingBox if it the attribute definition is already created. However, if I create it in autoLISP and save that object to a variable, then run the getBoundingBox, it fails.
jtoverka
Re: textbox
« Reply #8 on: March 22, 2020, 09:00:41 PM »
Check the code below, I cannot seem to get the bounding box. That is why I created that textboxODBX function.
; Name: J. Overkamp
; Date: 03/18/2020
; Parameters:
;   document          - document object
;   blockName         - string blockname for balloon
;   defaultTextString - string to use as the item number
;   circleDiameter    - string from BALL_CDIA from WD_PNLM
;   circleGap         - string from BALL_CGAP from WD_PNLM
;   circleFit         - string from BALL_CFIT from WD_PNLM
;   offset2D          - reposition block
;   pBal_lay          - string from PBAL_LAY  from WD_PNLM
;   pItem_lay         - string from PBAL_LAY  from WD_PNLM
; Function:
;   Create a circle balloon block definition
; Return:
;   vla block definition
(defun JO:circleBalloonBlock (document blockName defaultTextString circleDiameter circleGap circleFit textSize offset2D pBal_lay pItem_lay / blocks block attributeObject boundingBox diameter radius origin2D circle)
    document
    document pBal_lay
    document pItem_Lay
  (setq
    attributeObject
    (vla-addAttribute
      block           ; object
      0               ; attMode
      ""              ; attPrompt
      "B_ITEM"        ; attTag
      ""              ; attValue
  (vla-put-alignment   attributeObject acAlignmentMiddle)
  (or
    defaultTextString
    (setq defaultTextString "")
  (if (wcmatch defaultTextString "")
      (vla-put-TextString  attributeObject "XX")
      (setq boundingBox (JO:textboxODBX attributeObject))
      (vla-put-TextString  attributeObject defaultTextString)
  ;(setq boundingBox (vl-catch-all-apply 'vla-getBoundingBox (list attributeObject))) ; <----------------------------------------------------- Returns ERROR when uncommented
  (if (wcmatch circleFit "1")
      (if boundingBox
          (setq diameter
              (distance
                (nth 0 boundingBox)
                (nth 1 boundingBox)
              (atof circleGap)
              (atof circleGap)
          (setq diameter (+ (atof circleGap) (atof textSize)))
      (setq diameter (atof circleDiameter))
  (setq circle
    (vla-AddCircle block
      (vlax-3d-point
      radius
  (vla-put-layer circle PBAL_LAY)
  block
(JO:circleBalloonBlock document "PNL1000" "9" "0.5" "0.25" "1" "0.25" '(0 0) "PBAL" "PITEM")
Re: textbox
« Reply #9 on: March 22, 2020, 10:09:31 PM »
The GetBoundingBox method works on attributes and attribute definitions provided the latter are hosted by the primary blocks (*Model_Space or *Paper_Space<n>). Said another way - the GetBoundingBox method will fail on attribute definitions hosted by a user defined block.
I've never had to do the latter (despite tons of the former) but if needed I'd create a temporary instance of the attribute definition of interest in *Model_Space or *Paper_Space using the properties as the original - capture the bounding box - then dump the temporary instance.
Quick and dirty example (untested but reasonably confident would work in odbx - edit: tested, works in odbx):
(defun get-attdef-bounding-box ( attdef / result )
    (vl-catch-all-apply
       '(lambda ( / doc ms layer props values temp foo )
            (setq
                ms     (vla-get-modelspace (setq doc (vla-get-document attdef)))
                layer  (vla-item (vla-get-layers doc) (vla-get-layer attdef))
                props '(height mode promptstring insertionpoint tagstring textstring)
                values (mapcar '(lambda (p) (vlax-get attdef p)) props)
                temp   (apply 'vlax-invoke (append (list ms 'addattribute) values))
                props  (append '(scalefactor textalignmentpoint textgenerationflag upsidedown) props)
                props  (append '(alignment backward height obliqueangle stylename rotation) props)
                foo    (lambda (p) (vl-catch-all-apply '(lambda ( ) (vlax-put temp p (vlax-get attdef p)))))
            (foreach p props (foo p))
            (vlax-invoke-method temp 'GetBoundingBox 'a 'b)
            (if a (setq result (mapcar 'vlax-safearray->list (list a b))))
            (if (minusp (vlax-get layer 'lock))
                (progn (vlax-put layer 'lock 0) (vlax-invoke temp 'delete) (vlax-put layer 'lock -1))
    result
A complete aside - AutoCAD does some slight of hand block mgmt voodoo on behalf of the block edit command. If you examine objects while in the block edit environment you will notice the handles do not correspond to those in the actual block being edited. <edumacated guess> Said command creates a temporary block def matching the original block def every time the block edit command is invoked (i.e. handles increment every time). If changes are saved when exiting the block edit environment the original block def is revised per the changes in the temp block def.
Cheers.
« Last Edit: March 23, 2020, 12:05:19 AM by MP »
jtoverka
Re: textbox
« Reply #10 on: March 23, 2020, 07:12:25 AM »
So I tested the code and it gets the bounding box of the tag string and not the text string. I have an attribute called B_ITEM and it is getting the bounding box of that, whereas I want the bounding box of the text string which is generally a number between 1 and ~150. The method I made above does that.
Re: textbox
« Reply #11 on: March 23, 2020, 07:48:33 AM »
Normal behaviour of a getboundingbox call on an attribute instance would reflect the value of the textstring property.
Normal behaviour of a getboundingbox call on an attribute definition would reflect the value of the tagstring property.
I am satisfied what I coded reflects this. Code could be written to spawn an attribute instance from an attribute definition but other fish wait impatiently in my pan.
You have a solution, all is good, cheers.
ahsattarian
Re: textbox
« Reply #12 on: November 22, 2020, 08:38:52 AM »
This Helps u   :
(defun mytextbox (sj / lij)
  (setq enj (entget sj))
  (setq typj (strcase (cdr (assoc 0 enj)) t))
    ((= typj "text")
     (setq hi (cdr (assoc 40 enj)))
     (setq ang (cdr (assoc 50 enj)))
     (setq tbx (textbox enj))
     (command "ucs" "world")
     (command "ucs" "origin" (trans (cdr (assoc 10 enj)) 0 1))
     (command "ucs" "z" (* ang (/ 180.0 pi)))
     (setq p1 (trans (car tbx) 1 0))
     (setq p2 (trans (list (caadr tbx) (cadar tbx)) 1 0))
     (setq p3 (trans (cadr tbx) 1 0))
     (setq p4 (trans (list (caar tbx) (cadadr tbx)) 1 0))
     (setq lij (list p1 p2 p3 p4))
    ((= typj "mtext")
     (setq wi (cdr (assoc 42 enj)))
     (setq hi (cdr (assoc 43 enj)))
     (setq po (trans (cdr (assoc 10 enj)) (cdr (assoc -1 en)) 1))
     (setq ju (cdr (assoc 71 enj)))
       ((= ju 1)
   (setq p1 (polar po (- ang (* pi 0.5)) hi)) ; lower-left
   (setq p2 (polar p1 ang wi))        ; lower-right
   (setq p3 (polar po ang wi))        ; upper-right
   (setq p4 po)              ; upper-left
       ((= ju 2)
   (setq p3 (polar po ang (/ wi 2)))
   (setq p4 (polar po (+ ang pi) (/ wi 2)))
   (setq p1 (polar p4 (- ang (* pi 0.5)) hi))
       ((= ju 3)
   (setq p3 po)
   (setq p4 (polar po (+ ang pi) wi))
       ((= ju 4)
   (setq p4 (polar po (+ ang (* pi 0.5)) (/ hi 2)))
   (setq p3 (polar p4 ang wi))
       ((= ju 5)
   (setq p4 (polar po (- ang pi) (/ wi 2)))
   (setq p4 (polar p4 (+ ang (* pi 0.5)) (/ hi 2)))
       ((= ju 6)
   (setq p3 (polar po (+ ang (* pi 0.5)) (/ hi 2)))
   (setq p4 (polar p3 (+ ang pi) wi))
       ((= ju 7)
   (setq p1 po)
   (setq p3 (polar p2 (+ ang (* pi 0.5)) hi))
   (setq p4 (polar p1 (+ ang (* pi 0.5)) hi))
       ((= ju
   (setq p1 (polar po (+ ang pi) (/ wi 2)))
       ((= ju 9)
   (setq p2 po)
   (setq p1 (polar po (+ ang pi) wi))
  lij
Code Tags added by CAB
« Last Edit: November 22, 2020, 05:40:23 PM by CAB »
