0 objects scale removed.4 objects don't support annotation scale <1:50>.4 objects cannot remove scale.
::: Delete Annotative Scale Execpt Current;;; By Irneb;;; http://www.cadtutor.net/forum/showthread.php?53069-Annotative-troubles&p=359702&viewfull=1#post359702(defun c:ObjectScaleCurOnly (/ ss n scLst OSC:GetScales) (print "Select the objects you wish to modify: ") (if (or (setq ss (ssget "I")) (setq ss (ssget))) (progn ;; Define helper function to get scales attached to an entity (defun OSC:GetScales (en / ed xn xd cdn cdd asn asd cn cd sn sd cannoscale) (setq ed (entget en)) (if (and ;; Get the XDictionary attached to the object (setq xn (vl-position '(102 . "{ACAD_XDICTIONARY") ed)) (setq xn (cdr (nth (1+ xn) ed))) (setq xd (entget xn)) ;; Get the Context Data Management dictionary attached to the XDictionary (setq cdn (vl-position '(3 . "AcDbContextDataManager") xd)) (setq cdn (cdr (nth (1+ cdn) xd))) (setq cdd (entget cdn)) ;; Get the Annotation Scales dictionary attached to the CD (setq asn (vl-position '(3 . "ACDB_ANNOTATIONSCALES") cdd)) (setq asn (cdr (nth (1+ asn) cdd))) (setq asd (entget asn)) ;; Get the 1st scale attached (setq cn (assoc 3 asd)) (setq cn (member cn asd)) ) ;; Step through all scales attached (while cn (if (and (= (caar cn) 350) ;It it's pointing to a scale record ;; Get the record's data (setq cd (entget (cdar cn))) ;; Get the Context data class (setq sn (assoc 340 cd)) (setq sd (entget (cdr sn))) (setq sn (assoc 300 sd)) ;; Check if the scale is already in the list (not (vl-position (cdr sn) scLst)) ) ;; Add it to the list (setq scLst (cons (cdr sn) scLst)) ) (setq cn (cdr cn)) ) ) ) ;; Find a list of scales used in selection (setq n (sslength ss)) (while (>= (setq n (1- n)) 0) (OSC:GetScales (ssname ss n)) ) ;; Add the current scale to the selection (setq cannoscale (getvar "CANNOSCALE")) (command "._ObjectScale" ss "" "_Add" cannoscale "") ;; Remove all other scales attached (command "._ObjectScale" ss "" "_Delete") (foreach n scLst (if (wcmatch (strcase n) (strcat "~" (strcase cannoscale))) (command n) ) ) (command "") ) ) (princ))
