Author Topic: DESKTOPANALYTICS  (Read 1673 times)
mailmaverick
DESKTOPANALYTICS
« on: March 17, 2020, 02:56:10 AM »
Autodesk is unreasonably collecting data of user files by internet through their DESKTOPANALYTICS program.
To all people, kindly disable it by typing DESKTOPANALYTICS and unchecking the option in the new window.
Also, is there a way to stop DESKTOPANALYTICS through LISP ?
tombu
  • ByLayer=>Not0
Re: DESKTOPANALYTICS
« Reply #1 on: March 17, 2020, 07:35:37 AM »
I was under the impression they were only collecting information on issues like crashes and other problems with their software so they could fix them. What data are they collecting we should be concerned with?
Tom Beauford P.S.M.
« Reply #2 on: March 17, 2020, 08:52:29 AM »
Reg key:
HKEY_CURRENT_USER\Software\Autodesk\MC3
    ADAOptIn
        0 = Opt out
        1 = Opt in
Easy enough to flip via lisp, if no one posts code I will later.
PS: You likely have to restart AutoCAD for it to "take".
mailmaverick
« Reply #3 on: April 02, 2020, 09:09:16 AM »
Dear MP,
Please post LISP code to do the required changes in registry.
Thanks.
tombu
  • ByLayer=>Not0
« Reply #4 on: April 02, 2020, 10:29:54 AM »
To toggle it off/on:
(defun c:ADAOptIn (/ key)
  (setq key "HKEY_CURRENT_USER\\Software\\Autodesk\\MC3")
  (if(=(vl-registry-read key "ADAOptIn")"0")
    (vl-registry-write key "ADAOptIn" "1")
    (vl-registry-write key "ADAOptIn" "0")
Enter ADAOptIn
Tom Beauford P.S.M.
« Reply #5 on: April 02, 2020, 10:36:20 AM »
tombu, maybe return the value set so the user knows which option they have set.
