I have found lisp routine from this site that I tried to use. Problem is that the LISP doesn't work.
Does anyone have LISP that merges multiple dxf files with eachother? Right now I open every file and selects + Copy and then uses the pasteorig command in autocad. But it takes pretty much time when you have over 250 dxf files.
