Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Help with a lisp: PASTEORIG in a new document
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Help with a lisp: PASTEORIG in a new document (Read 1904 times)
PM
Guest
on:
February 28, 2020, 03:40:25 AM »
Hi i need help with a lisp code. I want to select everything (only the oplen layers not the close or frozen) from one drawing and paste them with original coordinates in a new document from specific location. I try this code but when open the new document return to the previous and don't paste the selected part
Code - Auto/Visual Lisp:
[Select]
defun
c:test
ssget
"_x"
410
"Model"
command
"copyclip"
ssget
"_x"
410
"Model"
setq
acApp
vlax-get-acad-object
setq
acDocs
vla-get-documents
acApp
vla
open
acDocs
"c:
myfile
test
test.dwg"
command
"PASTEORIG"
princ
Logged
Tutulisper
Mosquito
Re: Help with a lisp: PASTEORIG in a new document
Reply #1 on:
February 28, 2020, 03:50:33 AM »
Hi,you can use "copyobjects " to the new document
this is the code maybe it useful.
[Select]
defun
c:tes
app docs doc objects ss i n sslist
setq
app
setq
doc
vla-get-activedocument
app
setq
docs
vla-get-documents
app
setq
ss
ssget
list
cons
410
Getvar
"CTAB"
setq
n
sslength
ss
i
0
repeat
n
setq
sslist
append
sslist
list
vlax
ename
vla-object
ssname
ss i
setq
i
1+
i
setq
objects
vlax
make
safearray
vlax-vbObject
cons
0
1-
n
vlax-safearray-fill
objects sslist
setq
doc_new
vla-add
docs
"acad.dwt"
vla-copyobjects
doc objects
vla-get-modelspace
doc_new
vla-saveas
doc_new
"e:
drawing.dwg"
vla
close
doc_new
princ
Last Edit: February 28, 2020, 04:22:02 AM by Tutulisper
Logged
PM
Guest
Reply #2 on:
February 28, 2020, 07:53:27 AM »
I have the same layers in the drawing and the same layers in the dwt but i use different colors in the drawing than in the dwt. When i run the code i miss the colors in the dwt. I want the insert drwing to take the colors from the dwt. Any option ?
Logged
PM
Guest
Reply #3 on:
February 28, 2020, 01:18:46 PM »
the first way if better to me ,but i have probleme with the paste in original coordinates.Any option?
[Select]
defun
c:test
ssget
"_x"
410
"Model"
command
"copyclip"
ssget
"_x"
410
"Model"
setq
acApp
setq
acDocs
vla-get-documents
acApp
vla
open
acDocs
"c:
myfile
test
test.dwg"
command
"PASTEORIG"
princ
Logged
PM
Guest
Reply #4 on:
February 28, 2020, 04:25:57 PM »
Ok i test again Tutulisper and works perfect. I want to add a layon command and a zoom extend command but is not working because when open the new document paste the drawing ,and return to the first drawing and do the lay on and zoom extend in the first drawing. Can any pne help ?
[Select]
defun
c:tes
setq
app
setq
doc
app
setq
docs
vla-get-documents
app
setq
ss
ssget
list
cons
410
Getvar
"CTAB"
setq
n
sslength
ss
i
0
repeat
n
setq
sslist
append
sslist
list
vlax
ename
vla-object
ssname
ss i
setq
i
1+
i
setq
objects
vlax
make
safearray
vlax-vbObject
cons
0
1-
n
vlax-safearray-fill
objects sslist
setq
doc_new
vla-add
docs
"acad.dwt"
vla-copyobjects
doc objects
vla-get-modelspace
doc_new
vla-saveas
doc_new
"e:
drawing.dwg"
vla
close
doc_new
princ
Logged
Tutulisper
Mosquito
Reply #5 on:
February 28, 2020, 09:17:57 PM »
I think lisp can not accitve the new document, so zoom the document have no idea ,the lisp reactor maybe can do it but i can not use it.
this code is only copy the objects to the new document.
you can modify the "lock" "freeze" state。
[Select]
defun
c:tes
app docs doc objects ss i n sslist objlay insyslay insyslayobj
setq
app
setq
doc
app
setq
docs
vla-get-documents
app
setq
modelspaceobjs
vla-get-ModelSpace
doc
setq
docs
vla-get-documents
app
vlax-for
obj modelspaceobjs
setq
objlay
Vla-Get-Layer
obj
setq
insyslay
tblobjname
"layer"
objlay
setq
insyslayobj
Vlax
Ename
Vla-Object
insyslay
; if the layer is on then add to the list
if
and
1
vlax-get
insyslayobj 'layeron
;layer is on
0
vlax-get
insyslayobj 'lock
;layer is not lock
0
vlax-get
insyslayobj 'freeze
;;layer is not freeze
progn
setq
sslist
append
sslist
list
obj
if
length
sslist
1
progn
setq
objects
vlax
make
safearray
vlax-vbObject
cons
0
1-
length
sslist
vlax-safearray-fill
objects sslist
setq
doc_new
vla-add
docs
"acad.dwt"
vla-copyobjects
doc objects
vla-get-modelspace
doc_new
vla-saveas
doc_new
"e:
drawing.dwg"
vla
close
doc_new
princ
Last Edit: February 28, 2020, 09:58:22 PM by Tutulisper
Logged
PM
Guest
Reply #6 on:
February 29, 2020, 08:50:26 AM »
Hi Tutulisper.I try yourr code but my layer ar stay off. Is any other way to do zoom extend and layon the new document ?
Logged
Tutulisper
Mosquito
Reply #7 on:
February 29, 2020, 09:41:44 AM »
can use scr to do it
[Select]
command
"._script"
scrfilename
in the scrfile like this code
open
"e:
\d
rawing.dwg"
ZOOM E qsave
close
Logged
PM
Guest
Reply #8 on:
February 29, 2020, 11:54:23 AM »
When the copy the object in the new document return to the previus file. Is any way to go back in the new document and zoom extend and lay on?
Logged
Tutulisper
Mosquito
Reply #9 on:
February 29, 2020, 08:47:39 PM »
Use lisp do it is difficult i have no idea.
you can use vba or c# very easy.
Logged
PM
Guest
Reply #10 on:
March 02, 2020, 02:39:37 PM »
Thanks for your time.I am not using script files ot vba. I will search more from a solution through lisp.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
