Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
StripFontFormat
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: StripFontFormat (Read 1679 times)
jbuzbee
Swamp Rat
StripFontFormat
on:
February 26, 2020, 11:35:41 AM »
Does anyone have a routine that will strip the font formating in Mtext?
I've lost mine
and don't have time to re-right it. Even a road map would be helpful
Thanks for any info!
Logged
James Buzbee
Windows 8
Slim©
Needs a day job
The Dude Abides...
Re: StripFontFormat
Reply #1 on:
February 26, 2020, 12:03:38 PM »
http://www.theswamp.org/index.php?topic=31584.0
Logged
Seagull
London, England
WWW
Re: StripFontFormat
Reply #2 on:
February 26, 2020, 02:32:56 PM »
Here's
a lightweight program to strip all formatting (you can't pick & choose as you can with StripMText).
Logged
Lee Mac Programming
Twitter
Exchange App Store
jbuzbee
Swamp Rat
Re: StripFontFormat
Reply #3 on:
February 27, 2020, 12:18:44 PM »
Thanks Lee
Logged
James Buzbee
Windows 8
ahsattarian
Newt
Re: StripFontFormat
Reply #4 on:
November 22, 2020, 02:47:30 PM »
check these :
Code - Auto/Visual Lisp:
[Select]
defun
c:mtxstrip1
setq
ss
ssget
0
"mtext,dimension,multileader"
setq
n
sslength
ss
setq
k
1
repeat
n
setq
k
1+
k
setq
s
ssname
ss k
setq
en
entget
s
setq
typ
strcase
cdr
assoc
0
en
t
setq
ass
1
cond
typ
"multileader"
setq
ass
304
setq
txt1
cdr
assoc
ass en
setq
txt2
setq
i
1
setq
len
strlen
txt1
while
i len
setq
let
substr
txt1 i
1
if
let
progn
setq
i
1+
i
setq
let
substr
txt1 i
1
if
or
let
let
let
let
"P"
setq
txt2
strcat
txt2
let
while
and
let
i len
setq
i
1+
i
setq
let
substr
txt1 i
1
cond
and
let
let
setq
txt2
strcat
txt2 let
setq
i
1+
i
cond
txt1 txt2
setq
en
subst
cons
ass txt2
assoc
ass en
en
entmod
en
[Select]
defun
c:mtxstrip2
setq
ss
ssget
0
"MTEXT"
setq
n
sslength
ss
setq
k
1
repeat
n
setq
k
1+
k
setq
s
ssname
ss k
setq
obj
vlax
ename
vla-object
s
setq
text
vla-get-textstring
obj
setq
len
strlen
text
setq
i
0
setq
libad '
123
125
92
59
setq
text2
setq
bad
0
repeat
len
setq
i
1+
i
setq
let
substr
text i
1
setq
asci
ascii
let
cond
asci
92
setq
bad
1
cond
and
asci
59
bad
1
setq
bad
0
cond
and
not
member
asci libad
bad
0
setq
text2
strcat
text2 let
if
and
let
setq
let2
substr
text
1+
i
1
let2
"P"
progn
setq
text2
strcat
text2 let let2
setq
bad
0
setq
i
1+
i
vla-put-textstring
obj text2
EDIT (John): Added code tags.
Last Edit: December 10, 2020, 03:24:14 PM by John Kaul (Se7en)
Logged
roy_043
Water Moccasin
BricsCAD 18
Re: StripFontFormat
Reply #5 on:
November 22, 2020, 03:18:58 PM »
@ahsattarian:
Can you please use code tags? Thanks.
You can either use the Code dropdown list and select AutoLisp, or use the '#' button.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
StripFontFormat
