Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
.NET
Topic:
in ucs how to get BlockReference's GeometricExtents
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: in ucs how to get BlockReference's GeometricExtents (Read 2217 times)
Tutulisper
Mosquito
on:
February 26, 2020, 11:01:16 AM »
in ucs how to get BlockReference's real GeometricExtents
Logged
gile
Gator
Marseille, France
WWW
Re: in ucs how to get BlockReference's GeometricExtents
Reply #1 on:
February 26, 2020, 01:15:29 PM »
GeometricExtents are always about WCS.
If you want the extents about the current UCS, you have to transform the BlockReference from UCS to WCS, get the extents and transform back the block reference and its extents to UCS.
Code - C#:
[Select]
CommandMethod
"UCSBBOX"
public
static
void
GetExtentsAboutUcs
var
doc
Application
DocumentManager
MdiActiveDocument
var
db
doc
Database
var
ed
doc
Editor
var
peo
new
PromptEntityOptions
\n
Select block reference: "
peo
SetRejectMessage
\n
Selected object is not a block reference."
peo
AddAllowedClass
typeof
BlockReference
true
var
per
ed
GetEntity
peo
if
per
Status
PromptStatus
OK
return
var
ucs
ed
CurrentUserCoordinateSystem
using
var
tr
db
TransactionManager
StartTransaction
var
br
BlockReference
tr
GetObject
per
ObjectId
, OpenMode
ForWrite
br
TransformBy
ucs
Inverse
var
exts
br
GeometricExtents
using
var
pline
new
Polyline
pline
AddVertexAt
0
new
Point2d
exts
MinPoint
X
, exts
MinPoint
Y
0.0
0.0
0.0
pline
AddVertexAt
1
new
Point2d
exts
MaxPoint
X
, exts
MinPoint
Y
0.0
0.0
0.0
pline
AddVertexAt
2
new
Point2d
exts
MaxPoint
X
, exts
MaxPoint
Y
0.0
0.0
0.0
pline
AddVertexAt
3
new
Point2d
exts
MinPoint
X
, exts
MaxPoint
Y
0.0
0.0
0.0
pline
Closed
true
pline
SetDatabaseDefaults
var
btr
BlockTableRecord
tr
GetObject
db
CurrentSpaceId
, OpenMode
ForWrite
btr
AppendEntity
pline
tr
AddNewlyCreatedDBObject
pline,
true
pline
TransformBy
ucs
br
TransformBy
ucs
tr
Commit
Logged
Tutulisper
Mosquito
Reply #2 on:
February 26, 2020, 10:03:50 PM »
thanks ,if i want get "Polyline" or "Line" in the BlockReference
how can i transform the Coordinate system。
Code - C#:
[Select]
LispFunction
"Blkbox"
public
static
ResultBuffer Blkbox
ResultBuffer rb
Document curDoc
Application
DocumentManager
MdiActiveDocument
Database db
HostApplicationServices
WorkingDatabase
Editor ed
Application
DocumentManager
MdiActiveDocument
Editor
if
rb
null
return
null
TypedValue
tvValues
rb
AsArray
using
Transaction trans
db
TransactionManager
StartTransaction
ResultBuffer result
new
ResultBuffer
BlockTable bt
BlockTable
trans
GetObject
db
BlockTableId
, OpenMode
ForRead
Entity ent
Entity
trans
GetObject
ObjectId
tvValues
0
Value
, OpenMode
ForRead
if
ent
null
ent
GetType
typeof
BlockReference
BlockReference br
BlockReference
trans
GetObject
ObjectId
tvValues
0
Value
, OpenMode
ForRead
string
blkname
br
Name
ed
WriteMessage
\n
Block Name: ("
blkname
ObjectId blockRecordId
bt
blkname
BlockTableRecord blockRecord
BlockTableRecord
blockRecordId
GetObject
OpenMode
ForRead
Extents3d tmpExtents3D
new
Extents3d
int
num
0
foreach
ObjectId entID
in
blockRecord
Entity entity
Entity
trans
GetObject
entID, OpenMode
ForRead
// string str = entity.GetType().Name;
// get "Polyline" or "Line"
if
entity
GetType
Name
"Polyline"
entity
GetType
Name
"Line"
Extents3d tmp
entity
GeometricExtents
tmpExtents3D
AddExtents
tmp
num
num
1
if
num
0
Point3d maxpt
tmpExtents3D
MaxPoint
Point3d minpt
tmpExtents3D
MinPoint
// Translate the OCS to WCS
Matrix3d mt
br
BlockTransform
Point3d ptmax
maxpt
TransformBy
mt
Point3d ptmin
minpt
TransformBy
mt
result
Add
new
TypedValue
int
LispDataType
Point3d
, ptmax
result
Add
new
TypedValue
int
LispDataType
Point3d
, ptmin
else
return
null
trans
Commit
return
result
Last Edit: February 26, 2020, 10:15:22 PM by Tutulisper
Logged
gile
Gator
Marseille, France
WWW
Reply #3 on:
February 27, 2020, 02:17:32 AM »
I'm not sure to understand what you try to achieve but here's an example to get the UCS coordinates of the extents about UCS of lines and polylines contained in the block reference.
Code - C#:
[Select]
LispFunction
"Blkbox"
public
static
ResultBuffer Blkbox
ResultBuffer rb
// validation of the LISP argument
if
rb
null
return
null
TypedValue
tvValues
rb
AsArray
if
1
tvValues
Length
return
null
if
tvValues
0
TypeCode
int
LispDataType
ObjectId
return
null
ObjectId id
ObjectId
tvValues
0
Value
if
id
ObjectClass
DxfName
"INSERT"
return
null
Document curDoc
Application
DocumentManager
MdiActiveDocument
Database db
WorkingDatabase
Editor ed
Application
DocumentManager
MdiActiveDocument
Editor
Matrix3d ucs2wcs
ed
Matrix3d wcs2ucs
ucs2wcs
Inverse
using
Transaction trans
db
TransactionManager
StartTransaction
ResultBuffer result
new
ResultBuffer
BlockReference br
BlockReference
trans
GetObject
id, OpenMode
ForRead
string
blkname
br
Name
ed
WriteMessage
\n
Block Name: ("
blkname
using
DBObjectCollection entitySet
new
DBObjectCollection
br
Explode
entitySet
new
Extents3d
int
num
0
foreach
Entity entity
in
entitySet
if
entity
is
Polyline
entity
is
Line
entity
TransformBy
wcs2ucs
tmpExtents3D
AddExtents
entity
GeometricExtents
num
entity
Dispose
if
0
num
result
Add
new
TypedValue
int
LispDataType
Point3d
, tmpExtents3D
MinPoint
result
Add
new
TypedValue
int
LispDataType
Point3d
, tmpExtents3D
MaxPoint
trans
Commit
return
result
To test the result:
Code - Auto/Visual Lisp:
[Select]
setq
bbox
blkbox
car
entsel
command
"_.rectang"
"_non"
car
bbox
"_non"
cadr
bbox
But all this can be done directly with LISP, here's an example:
[Select]
;; gc:TMatrixFromTo
;; Returns the (4x4) transformation matrix from a coordinate system to another one
;; (same arguments type as 'trans')
;; Arguments
;; from : source coordinate system (integer, vector or ename)
;; to : destination coordinate system (integer, vector or ename)
defun
gc
:TMatrixFromTo
from to
append
mapcar
function
lambda
v o
append
trans
v from to T
list
o
1
0
0
0
1
0
0
0
1
trans
0
0
0
to from
0
0
0
1
;; gc:UcsBoundingBox
;; Returns the UCS coordinates of the entity extents (bounding box)
;; about the current UCS
;; Arguments
;; obj: an entity (ENAME or VLA-OBJCET)
;; _OutputMinPtSym: a quoted symbol (output)
;; _OutputMaxPtSym: a quoted symbol (output)
defun
gc
:UcsBoundingBox
obj _OutputMinPtSym _OutputMaxPtSym
vl-load-com
and
type
obj
'ENAME
setq
obj
vlax
ename
vla-object
obj
vla-TransformBy
obj
vlax-tmatrix
gc
:TMatrixFromTo
1
0
vla-GetBoundingBox
vla-TransformBy
obj
vlax-tmatrix
gc
:TMatrixFromTo
0
1
set
_OutputMinPtSym
vlax
safearray
list
eval
_OutputMinPtSym
set
_OutputMaxPtSym
vlax
safearray
list
eval
_OutputMaxPtSym
using:
[Select]
gc
:UcsBoundingBox
car
entsel
'minPt 'maxPt
command
"_.rectang"
"_non"
minPt
"_non"
maxPt
Logged
Tutulisper
Mosquito
Reply #4 on:
February 27, 2020, 03:04:23 AM »
thank you!
your code is very nice and Solved the problem
for some BlockReference it can not get the "GetBoundingBox" so it's only to go inside the BlockReference to get it.
Last Edit: February 27, 2020, 11:38:10 AM by Tutulisper
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
.NET
Topic:
