(setq TT (EVAL (quote(LAMBDA (K ) (ALERT K ) ) ) ))
(TT "dd" )
This is what it looks like when compiled:
Offset 0 1 2 3 4 5 6 7 8 9 A B C D E F
00000000 0D 0A 20 46 41 53 34 2D 46 49 4C 45 20 3B 20 44 FAS4-FILE ; D
00000010 6F 20 6E 6F 74 20 63 68 61 6E 67 65 20 69 74 21 o not change it!
00000020 0D 0A 31 0D 0A 31 20 24 20 24 0D 0A 31 32 33 20 1 1 $ $ 123
00000030 36 20 24 14 01 01 01 00 32 00 32 22 2A 39 01 00 6 $ 2 2"*9
00000040 55 01 00 02 00 64 64 5B 54 54 00 45 56 41 4C 00 U dd[TT EVAL
00000050 00 5B 4C 41 4D 42 44 41 00 00 5B 4B 00 00 39 01 [LAMBDA [K 9
00000060 00 5B 41 4C 45 52 54 00 00 5B 4B 00 00 39 02 00 [ALERT [K 9
00000070 39 03 00 01 01 43 00 00 06 00 0A 01 5C 00 00 43 9 C \ C
00000080 00 00 01 00 0A 01 43 06 00 00 00 1C 14 01 00 00 C
00000090 00 09 05 00 0A 09 04 00 34 00 07 35 01 03 00 03 4 5
000000A0 0B 06 02 00 0A 09 01 00 35 01 02 00 03 16 15 00 5
000000B0 B6 81 1A 52 B3 0A 3B 66 61 73 34 20 63 72 75 6E ? R?;fas4 crun
000000C0 63 68 0A 3B 24 3B 41 32 2F 31 38 2F 32 30 ch ;$;A2/18/20
(setq tt (eval(function(lambda (k) (alert k) ))))
(tt "dd")
00000020 0D 0A 32 36 0D 0A 33 20 24 14 01 01 01 00 09 02 26 3 $
00000030 00 5C 00 00 18 03 00 03 02 00 35 01 01 00 03 19 \ 5
00000040 01 00 16 24 0D 0A 31 33 39 20 37 20 24 14 01 01 $ 139 7 $
00000050 01 00 32 00 32 2A 2A 39 01 00 55 01 00 02 00 64 2 2**9 U d
00000060 64 5B 54 54 00 45 56 41 4C 00 00 56 6B 77 6F 74 d[TT EVAL Vkwot
00000070 65 00 00 01 01 43 00 00 06 00 0A 32 00 32 1A 2A e C 2 2 *
00000080 39 01 00 5B 41 4C 45 52 54 00 4B 00 00 5C 00 00 9 [ALERT K \
00000090 43 00 00 03 00 0A 5C 00 00 32 00 5B 2D 6C 61 6D C \ 2 [-lam
000000A0 62 64 61 2D 00 00 3A 01 43 06 00 01 00 1C 14 01 bda- : C
000000B0 00 00 00 09 05 00 0A 57 00 00 00 00 09 06 00 51 W Q
000000C0 01 04 00 01 00 35 01 03 00 03 0B 06 02 00 0A 09 5
000000D0 01 00 35 01 02 00 03 16 18 00 A9 8A FC F9 EA 3D 5 ?
000000E0 9D EE 0A 3B 66 61 73 34 20 63 72 75 6E 63 68 0A ?;fas4 crunch
000000F0 3B 24 3B 41 32 2F 31 38 2F 32 30 ;$;A2/18/20
The following points can be seen:1. No function is defined when quote is used.When you use function, you define a function, -lambda-.When quote is used, (alert k) is run as a table.3. When using function, alert and k are two separate strings.Conclusion: when using quote, lambda is not compiled into a function. With function, a lambda is compiled into a function that can be optimized quickly.The so-called optimization is that you can access the function entrance address quickly and directly, without looking up the address corresponding to the function name and then calling it.
