Author Topic: MOVEBAK  (Read 2416 times)
capsochist
MOVEBAK
« on: February 24, 2020, 07:01:45 PM »
Hi there,
I am trying to place a 'MOVEBAK' line of code in my company acaddoc.lsp which points to a shared server backup location as I have not found a way to do this through the AutoCAD 'Open/Save' Options dialog.
Is there a line of code I could add to the below, so that the backup file would be saved into a folder with the current CAD users name (i.e, H:\Backup\CAD\username)? Username would need to be created by the code initiating the 'MOVEBAK' command since there are over 200 people in our firm.
  1. (command "MOVEBAK" "H:\Backup\CAD")
Thank you!
Stefan
Re: MOVEBAK
« Reply #1 on: February 24, 2020, 07:25:49 PM »
  1.     (setq dir
  2.       (strcat
  3.         "H:\\Backup\\CAD\\"
  4.         (getenv "UserName")
  5.       )
  6.     )
  7.   )
  8.   (setenv "AcetMoveBak" dir)
  9. )
capsochist
Re: MOVEBAK
« Reply #2 on: February 25, 2020, 11:30:28 AM »
  1.     (setq dir
  2.       (strcat
  5.       )
  6.     )
  7.   )
  9. )
Thank you so much! Would you mind providing comments so I can understand what is happening if I would like to make changes in the future?
For example, I am thinking of having the BAK files actually point to N:\_2019\1019200\CAD\BAK\Username
The location of this would need to pull the directory for each file based on the file location currently being worked in.
Thanks again!
Re: MOVEBAK
« Reply #3 on: February 25, 2020, 12:20:42 PM »
See if you can follow this. Welcome to TheSwamp :)
  1. (defun c:bak (/ dir)
  2.   ;; Make the BAK subfolder in the working drawing
  3.   (vl-mkdir (strcat (setq dir (getvar 'dwgprefix)) "BAK"))
  4.   ;; Make the BAK\Username subfolder in the working drawing
  5.   (vl-mkdir (setq dir (strcat dir "\\BAK\\" (getenv "UserName"))))
  6.   ;; If the directory exists
  7.     ;; Set the environment variable
  9.   )
  10.   (princ)
  11. )
« Last Edit: February 25, 2020, 02:07:28 PM by ronjonp »
Marc'Antonio Alessi
  • Marco
Re: MOVEBAK
« Reply #4 on: February 25, 2020, 12:30:39 PM »
  5.   (vl-mkdir (setq dir (strcat d "BAK\\" (getenv "UserName"))))
  9.   )
  10.   (princ)
  11. )
(vl-mkdir (setq dir (strcat dir "BAK\\" (getenv "UserName"))))  :-)
ribarm
  • Marko Ribar, architect
Re: MOVEBAK
« Reply #5 on: February 25, 2020, 01:02:27 PM »
M.R. on Youtube
capsochist
Re: MOVEBAK
« Reply #6 on: February 25, 2020, 01:38:36 PM »
  9.   )
  10.   (princ)
  11. )
Thank you, I think I follow the comment explanations, which are relatively straight forward. Before moving the backup, I just need to pull the directory as a variable so the function knows what sandbox to operate within. I also appreciate the warm welcome!
To be clear for anyone who finds this post useful, removing the general container for this code, allows it to run within the acaddoc.lsp
  1. ;; Make the BAK subfolder in the working drawing
  2.   (vl-mkdir (strcat (setq dir (getvar 'dwgprefix)) "BAK"))
  3.   ;; Make the BAK\Username subfolder in the working drawing
  4.   (vl-mkdir (setq dir (strcat dir "BAK\\" (getenv "UserName"))))
  5.   ;; If the directory exists
  6.     ;; Set the environment variable
  7.     (setenv "AcetMoveBak" dir)
  8.   )
without needing the following code:
  1. (LOAD "Z:/LD_CONFIG/LD_Lisp/BAK.lsp");; LOAD BAK COMMAND TO DIRECTORY
  2. (COMMAND "BAK");; CREATE AND EXECUTE BAK LOCATION THIS DWG
Please let me know if you feel this is bad practice for acaddoc.lsp so long as it is commented on clearly.
Re: MOVEBAK
« Reply #7 on: February 25, 2020, 02:06:25 PM »
Oops  :evil: .. fixed above.
Re: MOVEBAK
« Reply #8 on: February 25, 2020, 02:16:06 PM »
  9.   )
  10.   (princ)
  11. )
  8.   )
If you want to run this on startup you can call like so (c:bak). This will keep the 'dir' variable localized. I also added a check for drawing name and read-only.
  2.   ;; If the drawing has been named and is not read-only
  3.   (if (= 1 (getvar 'dwgtitled) (getvar 'writestat))
  4.     (progn ;; Make the BAK subfolder in the working drawing
  5.            (vl-mkdir (strcat (setq dir (getvar 'dwgprefix)) "BAK"))
  6.            ;; Make the BAK\Username subfolder in the working drawing
  7.            (vl-mkdir (setq dir (strcat dir "\\BAK\\" (getenv "UserName"))))
  8.            ;; If the directory exists
  9.            (if (vl-file-directory-p dir)
  10.              ;; Set the environment variable
  11.              (setenv "AcetMoveBak" dir)
  12.            )
  13.     )
  14.   )
  15.   (princ)
  16. )
  17. (c:bak)
Also .. the previous code you used had a typo in it. Use this post as your base.
