Author Topic: LM:intersections Doesn't work as it should  (Read 1436 times)
rayakmal
« on: February 24, 2020, 05:34:58 PM »
I use LM:intersections often, but sometimes the result is not as intended.
(defun c:inter ( / obj1 obj2 )
    (if (and (setq obj1 (car (entsel "\nSelect 1st Object: ")))
             (setq obj2 (car (entsel "\nSelect 2nd Object: ")))
        (foreach pnt (LM:intersections (vlax-ename->vla-object obj1) (vlax-ename->vla-object obj2) acextendnone)
            (entmake (list '(0 . "POINT") (cons 10 pnt)))
(defun LM:Intersections ( obj1 obj2 mode / l r )
    (setq l (vlax-invoke obj1 'intersectwith obj2 mode))
    (repeat (/ (length l) 3)
        (setq r (cons (list (car l) (cadr l) (caddr l)) r)
              l (cdddr l)
    (reverse r)
I attached the drawing, I use a UTM System Coordinate, the result: the point lies not on the Polyline.
I don't have this problem if the objects are situated near (0,0) (I use Autocad 2009).
Anyone can help me solve this problem?
I am thinking about working in UCS and transform the result back to WCS but I don't have any knowledge of this and right now need a fast solution.
Any pointer or help will be appreciated. Thanks
« Last Edit: February 24, 2020, 05:54:56 PM by rayakmal »
VovKa
  • Ukraine
rayakmal
Re: LM:intersections Doesn't work as it should
« Reply #2 on: February 24, 2020, 11:57:27 PM »
https://www.theswamp.org/index.php?topic=46848.0
Thanks for the pointer, VovKa. After I tried all the sample functions on the thread I realized those are not what I'm looking for, then I came up with this code, it was inspired by CAB's codes BreakObjects.lsp and it works like a charm. Problem Solved.
;; Quick & Dirty Programming:
(defun c:BRK ( / en1 en2 iplist)
   (setq en1 (entsel "\n#1 >> : ")
         en1 (vlax-ename->vla-object (car en1))
         en2 (entsel "\n#2 >> : ")
         en2 (vlax-ename->vla-object (car en2))
   (setq iplist (get_interpts en1 en2))
   (setq iplist (list->3pair iplist))
   (if iplist
      (foreach n iplist
        (entmake (list '(0 . "POINT") (cons 10 n)))
;;;================BORROWED FROM BreakObjects.lsp ]====================
;;; Author: Copyright© 2006-2008 Charles Alan Butler
;;; Contact @  www.TheSwamp.org
;;; Requirements: objects must have the same z-value
;;;   THIS SOFTWARE IS PROVIDED "AS IS" WITHOUT EXPRESS OR IMPLIED     ;
;;;   WARRANTY.  ALL IMPLIED WARRANTIES OF FITNESS FOR ANY PARTICULAR  ;
;;;   PURPOSE AND OF MERCHANTABILITY ARE HEREBY DISCLAIMED.            ;
;;;  You are hereby granted permission to use, copy and modify this    ;
;;;  software without charge, provided you do so exclusively for       ;
;;;  your own use or for use by others in your organization in the     ;
;;;  performance of their normal duties, and provided further that     ;
;;;  the above copyright notice appears in all copies and both that    ;
;;;  copyright notice and the limited warranty and restricted rights   ;
;;;  notice below appear in all supporting documentation.              ;
  ;;  return a list of lists grouped by 3 from a flat list
  (defun list->3pair (old / new)
    (while (setq new (cons (list (car old) (cadr old) (caddr old)) new)
                 old (cdddr old)))
    (reverse new)
;;  return a list of intersect points
(defun get_interpts (obj1 obj2 / iplist)
  (if (not (vl-catch-all-error-p
             (setq iplist (vl-catch-all-apply
                            'vlax-safearray->list
                            (list
                              (vlax-variant-value
                                (vla-intersectwith obj1 obj2 acextendnone)
    iplist
« Reply #3 on: February 25, 2020, 10:58:47 AM »
Glad you got it sorted out.  8)
