Author Topic: Fas and VLX program protectors ver 1.05e  (Read 8408 times)
baitang36
« on: February 24, 2020, 02:00:09 AM »
This program is a gift to LSP programming fans, after this program encryption VLX
and FAS files can not be decomcompiled.
It's very easy to use, click start, select a VLX or a fas file you want to encrypt,
click open, click ok, and the encryption is successful.
Encrypted files and source files in the same directory. Add _p to the filename。
If you have any Suggestions, please contact the author of this program sheng
(baitang36) email: 5520971@qq.com
2020-02-24  Ji'nan China
EDIT (John): Removed attachment.
« Last Edit: February 24, 2020, 02:36:28 PM by John Kaul (Se7en) »
Re: Fas and VLX program protectors ver 1.05e
« Reply #1 on: February 24, 2020, 02:39:22 PM »
Hello baitang36,
Please refrain from attaching binary/compiled files to a post. If you wish to share a binary/compiled file please ask for a private message or an email from people who are interested.
VovKa
  • Ukraine
« Reply #2 on: February 24, 2020, 04:51:55 PM »
i've downloaded and tried baitang36's tool
not on my PC of course :)
it changes certain byte sequences in the vlx file
which i suspect baffles the decompiler
baitang36
« Reply #3 on: February 24, 2020, 06:56:08 PM »
Hello baitang36,
Thank you
Please email me if you are interested
5520971@qq.com
baitang36
« Reply #4 on: February 24, 2020, 06:59:37 PM »
If you have decompiler software, try it out.I tried fastolsp.exe and it worked. A lot of net friend have tried, confirm effective.
VovKa
  • Ukraine
« Reply #5 on: February 25, 2020, 06:28:14 AM »
i've never used this tool
i don't have it
baitang36
« Reply #6 on: February 25, 2020, 07:18:45 AM »
i don't have it
If others are like you, the tool is useless.
VovKa
  • Ukraine
« Reply #7 on: February 25, 2020, 08:53:14 AM »
fastolsp.exe does a good job?
how does the decompiled fas looks like?
ribarm
  • Marko Ribar, architect
« Reply #8 on: February 25, 2020, 02:29:19 PM »
I can't decompile neither VLX, nor VLX-P version, but now that you provided "protection" - P, I believe OP can decompile any version he gets in his hands...
But I don't care like VovKa, to me VLX as it is is fairly good compilation...
M.R. on Youtube
« Reply #9 on: February 25, 2020, 03:21:16 PM »
I think I only compiled one program for use and it was essentially just for packaging/ease of use reasons more then protection.
baitang36
« Reply #10 on: February 25, 2020, 08:20:03 PM »
Decompiled can be run directly.
You can provide an fas file and I'll decompile it for you
baitang36
« Reply #11 on: February 25, 2020, 08:22:53 PM »
You can send me a VLX file and I will try it for you
baitang36
« Reply #12 on: February 25, 2020, 08:26:01 PM »
Since you package, just don't want people to see the source code. Decompiling tools are very popular today. Without protection, it's like running naked.
VovKa
  • Ukraine
« Reply #13 on: February 26, 2020, 04:58:05 AM »
here's the link https://1drv.ms/u/s!AqFURo8VgNilgQfymQwmAFprqvFA
baitang36
« Reply #14 on: February 26, 2020, 12:26:51 PM »
(DEFUN TEST ()
  (REPEAT (FIX PI)
    (AND (NOT (TERPRI)))
    (APPLY '+ (MAPCAR '* (LIST 1 2 3 4) (LIST 4 3 2 1)))
    (ALERT "OK")
