Hi.
I have a dynamic block with attributes that needs to be tagged. I am reading attributes and then inserting a tag block which contains these attribute values as fields.
I know how to do it if I only need to insert fields that contain values of the attributes.
However, I cannot figure out a way to insert a field with a simple formula that will do some math with attribute values.
In the attached example:
"Deck" is the block that needs to be tagged.
It has 2 attributes: "THICKNESS" and "HEIGHT". Values are always numeric.
I am inserting block named "Tag".
Inserting values of "THICKNESS" and "HEIGHT" as fields works fine.
I also need to insert a field formula that will be = "HEIGHT" - "THICKNESS"
Hoping to get some help here.
Thank you
