Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Move insert point of selected blocks to nearest polyline end point
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Move insert point of selected blocks to nearest polyline end point (Read 2357 times)
jtm2020hyo
Newt
on:
February 12, 2020, 01:53:38 AM »
1) I need to select some blocks and move then to the nearest end point of selected polyline.
2) I need to select some polyline and move theirs end points to the nearest selected block insert point.
This is possible?
Logged
https://www.patreon.com/jtm2020hyo
ribarm
Gator
Marko Ribar, architect
WWW
Re: Move insert point of selected blocks to nearest polyline end point
Reply #1 on:
February 12, 2020, 04:24:01 AM »
Here, try this routine :
Code - Auto/Visual Lisp:
[Select]
defun
c:stretch
move
blks
lws
ssblks sslws ch dpl spl lwx dm d np npl k lwxn pl p
while
or
prompt
\n
Select block INSERT references on unlocked layer(s)..."
not
setq
ssblks
ssget
"_:L"
0
"INSERT"
prompt
\n
Empty sel. set..."
while
or
prompt
\n
Select LWPOLYLINES on unlocked layer(s)..."
not
setq
sslws
ssget
"_:L"
0
"LWPOLYLINE"
prompt
\n
Empty sel. set..."
initget
1
"Stretch Move"
setq
ch
getkword
\n
Stretch LWPOLYLINE vertices to nearest BLOCKS or move BLOCKS to nearest LWPOLYLINE vertices [Stretch/Move] : "
if
ch
"Stretch"
progn
setq
dpl
apply
append
mapcar
lambda
x
mapcar
cdr
vl
remove
if
lambda
y
car
y
10
x
mapcar
entget
vl
remove
if
listp
mapcar
cadr
ssnamex
ssblks
foreach
lw
vl
remove
if
listp
mapcar
cadr
ssnamex
sslws
setq
spl
mapcar
lambda
x
trans
list
car
x
cadr
x
cdr
assoc
38
lwx
lw
0
mapcar
cdr
vl
remove
if
lambda
x
car
x
10
setq
lwx
entget
lw
foreach
p spl
setq
dm 1e
99
foreach
pp dpl
if
setq
d
distance
p pp
dm
setq
dm d np pp
setq
npl
cons
np npl
setq
npl
reverse
npl
setq
npl
mapcar
lambda
x
trans
x
0
lw
npl
setq
k
1
foreach
x lwx
if
car
x
10
setq
lwxn
append
lwxn
list
cons
10
nth
setq
k
1+
k
npl
setq
lwxn
append
lwxn
list
x
entupd
cdr
assoc
1
entmod
lwxn
setq
npl
nil
lwxn
nil
progn
foreach
lw
vl
remove
if
listp
mapcar
cadr
ssnamex
sslws
setq
pl
mapcar
lambda
x
trans
list
car
x
cadr
x
cdr
assoc
38
lwx
lw
0
mapcar
cdr
vl
remove
if
lambda
x
car
x
10
setq
lwx
entget
lw
setq
dpl
append
pl dpl
foreach
blk
vl
remove
if
listp
mapcar
cadr
ssnamex
ssblks
setq
dm 1e
99
foreach
pp dpl
if
setq
d
distance
if
null
p
setq
p
cdr
assoc
10
entget
blk
p
pp
dm
setq
dm d np pp
setq
p
nil
entupd
cdr
assoc
1
entmod
subst
cons
10
np
assoc
10
entget
blk
entget
blk
princ
M.R.
Logged
Marko Ribar, d.i.a.
(graduated engineer of architecture)
M.R. on Youtube
jtm2020hyo
Newt
Reply #2 on:
February 12, 2020, 10:14:14 PM »
awesome. thanks a lot.
how can I mark your answer as a solution?
Last Edit: February 12, 2020, 10:19:41 PM by jtm2018hyo
Logged
jtm2020hyo
Newt
Reply #3 on:
August 20, 2020, 06:44:43 PM »
this post is related:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/mass-move-block-to-nearest-polyline/m-p/9667727/highlight/true#M402999
maybe help to someone.
Logged
Pad
Bull Frog
Reply #4 on:
July 30, 2021, 02:16:16 PM »
Thanks Ribarm.
That helped me out a lot today!
P
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
