Author Topic: Polyline: List of vertex incl. middle of bulges?  (Read 1816 times)
Peter2
« on: February 04, 2020, 06:20:30 AM »
I know some lists for creating vertexlists and I know some "bulge-feature", but does someone know a routine which creates a list of vertex incl. the mids of bulges?
Thanks for hints!
Peter
BricsCAD V23
roy_043
  • BricsCAD 18
Re: Polyline: List of vertex incl. middle of bulges?
« Reply #1 on: February 04, 2020, 10:33:10 AM »
Simple solution that makes use of vlax-curve-getpointatparam. Points in WCS.
; (ListPolyPoints (vlax-ename->vla-object (car (entsel))))
(defun ListPolyPoints (obj / endParam param ret)
  (setq param 0)
  (setq endParam (vlax-curve-getendparam obj))
  (repeat (+ (fix endParam) (if (= :vlax-true (vla-get-closed obj)) 0 1))
    (setq ret (cons (vlax-curve-getpointatparam obj param) ret))
    (if (and (< param endParam) (/= 0 (vla-getbulge obj param)))
      (setq ret (cons (vlax-curve-getpointatparam obj (+ 0.5 param)) ret))
    (setq param (1+ param))
  (reverse ret)
Peter2
« Reply #2 on: February 04, 2020, 11:17:12 AM »
Great. Thanks!
Peter
BricsCAD V23
« Reply #3 on: February 04, 2020, 05:57:29 PM »
Here's another possible method using Vanilla AutoLISP:
  1. (defun lwverticesmidpoints ( enx / vt1 vt2 )
  2.     (if (setq vt1 (assoc 10 enx))
  3.         (if (setq vt2 (assoc 10 (cdr (member vt1 enx))))
  4.             (vl-list*
  5.                 (cdr vt1)
  6.                 (mapcar '+
  7.                     (mapcar '(lambda ( a b ) (/ (+ a b) 2.0)) (cdr vt1) (cdr vt2))
  8.                     (   (lambda ( v ) (mapcar '(lambda ( x ) (* 0.5 (cdr (assoc 42 enx)) x)) (list (cadr v) (- (car v)))))
  9.                         (mapcar '- (cdr vt2) (cdr vt1))
  10.                     )
  11.                 )
  12.                 (lwverticesmidpoints (member vt2 enx))
  13.             )
  14.             (list (cdr vt1))
  15.         )
  16.     )
  17. )
To test:
  1. (defun c:test ( / e )
  2.     (if (setq e (car (entsel)))
  3.         (foreach x (lwverticesmidpoints (entget e))
  4.             (entmake (list '(0 . "POINT") (cons 10 x)))
  5.         )
  6.     )
  7.     (princ)
  8. )
EDIT: To account for closed polylines:
  2.     (if (and (assoc 70 enx) (= 1 (logand 1 (cdr (assoc 70 enx)))))
  3.         (setq enx (append enx (list (assoc 10 enx))))
  4.     )
  5.     (if (setq vt1 (assoc 10 enx))
  6.         (if (setq vt2 (assoc 10 (cdr (member vt1 enx))))
  7.             (vl-list*
  8.                 (cdr vt1)
  9.                 (mapcar '+
  10.                     (mapcar '(lambda ( a b ) (/ (+ a b) 2.0)) (cdr vt1) (cdr vt2))
  11.                     (   (lambda ( v ) (mapcar '(lambda ( x ) (* 0.5 (cdr (assoc 42 enx)) x)) (list (cadr v) (- (car v)))))
  12.                         (mapcar '- (cdr vt2) (cdr vt1))
  13.                     )
  14.                 )
  15.                 (lwverticesmidpoints (member vt2 enx))
  16.             )
  17.             (list (cdr vt1))
  18.         )
  19.     )
  20. )
« Last Edit: February 04, 2020, 06:02:15 PM by Lee Mac »
