Author Topic: Need help with Attribute extraction for BricsCAD  (Read 2314 times)
Zodiac
« on: February 02, 2020, 09:05:58 PM »
This is a sample of a block that I have. The part highlighted in red is the block, the parts highlighted in yellow are the attribute tags in that block. What I would like is to be able to create a table where I can draw the "DESC-S" AND "PTNO-S" attributes, count the number of similar blocks in the same drawing and put the information into a table. I need this as I use several numbers of the same blocks in a drawing, and I don't want to count each part manually.
BIGAL
  • 40 + years of using Autocad
Re: Need help with Attribute extraction for BricsCAD
« Reply #1 on: March 08, 2020, 11:14:34 PM »
"count the number of similar blocks"
I do have something that will read up to 5 attributes deep and create a table, its being developed so happy to try out one of your dwg's as I need random test dwg's.
I do propose a small charge for it as it has taken a while to develop.
eg Block=Door has attributes Colour, handle, size.
Handle
result
Door Black Silver 820x2040 25
Door Black Gold 820x2040  23
Door Silver Silver 820x2040 13
etc
