Author Topic: Getting xdata  (Read 2132 times)
GDF
Getting xdata
« on: February 02, 2020, 12:30:52 PM »
I'm having trouble with retrieving xdata from this door block enclosed, using the TAG routine.
No results found for "bad argument type <NIL> ; expected SAFEARRAY at [vlax-safearray->list]".
Results for bad argument type <NIL> ; expected SAFEARRAY at [vlax-safearray->list]
Any ideas?
(defun ARCH:MsgBox2  (title buttons message time / return WshShell)
  (setq WshShell (vlax-create-object "WScript.Shell"))
  (setq return (vlax-invoke WshShell 'Popup message time title (itoa buttons)))
  (vlax-release-object WshShell)
  return)
;;;Here is a little example of storing x-data data ActiveX
;;;You have to get used to variants and safearrays to do it.
;;;Peter Jamtgaard
(defun GET-XDATA-DRWDWLVR  (/ ENAM EOBJ XDTYPE XDVALUE)
  (setq ENAM (cdar OBJX)
        EOBJ (vlax-ename->vla-object ENAM))
  (vla-getXData EOBJ "DRWDWLVR" 'XDTYPE 'XDVALUE)
  (mapcar '(lambda (X Y) (cons X (variant-value Y)))
          (vlax-safearray->list XDTYPE)
          (vlax-safearray->list XDVALUE)))
(defun C:TAG ()
    (setq scf (getvar "dimscale"))
    (setvar "cmdecho" 0)
    (setq objx (entget (car (entsel "\n* Select Door Wdw to Tag *"))))
    ;;(if (= objx nil)(setq objx (entget (entlast))))
    (setq xdli (cdr (assoc 2 (entget (cdar objx) '("DRWDWLVR")))))
    (setq xszx (substr xdli 5 (- (strlen xdli) 8)))
    (setq insx (cdr (assoc 10 objx)))
    ;;(setq insx (getpoint "\n* Pick Tag point..."))
    (setq angx (distof (princ (cdr (cadr (GET-XDATA-DRWDWLVR)))) 2))
    (setq xdrx (substr xdli 1 (- (strlen xdli) 6)))
    (setq xwdx (substr xdli 1 (- (strlen xdli) 6)))
    (setq xlvx (substr xdli 1 (- (strlen xdli) 6)))
    (setq xdr9 (substr xdli 1 (- (strlen xdli) 9)))
    (setq xwd9 (substr xdli 1 (- (strlen xdli) 9)))
    (setq xlv9 (substr xdli 1 (- (strlen xdli) 9)))
    (if (= M nil)
      (setq M 1))
    (setq nam1 (vl-list->string
                 (vl-remove-if-not
                   '(lambda (x) (< 47 x 58))
                   (vl-string->list (rtos (atoi xszx) 4 0)))))
    (setq nam2 (substr xdli 5 (- (strlen xdli) 8)))
    (setq nam3 (vl-list->string
                 (vl-remove-if-not
                   (vl-string->list (rtos (/ (atoi nam2) 2) 4 0)))))
    (setq nam4 (vl-list->string
                 (vl-remove-if-not
                   (vl-string->list (rtos (/ (atoi nam2) M) 4 0)))))
(ARCH:MsgBox2
      " Arch2Program© : Message"
      64
      (strcat
        "\n     DrWdwLvr Tag Settings"
        "\n---------------------------------------------------------------------------"
        "\n     Full Name:\t " xdli
        "\n     Tag Type:\t " (substr xdli 1 (- (strlen xdli) 6))
        "\n     Tag Size:\t " xszx
        "\n     Insert X:\t " (rtos (car insx) 2 2)
        "\n     Insert Y:\t " (rtos (cadr insx) 2 2)
        "\n     Angle:\t " (rtos angx 2 6)
      4)
Re: Getting xdata
« Reply #1 on: February 02, 2020, 12:55:39 PM »
Your test.dwg opens and is auto-recovered in 2020, with the block being erased due to wrongObjectType. Tried in 2018 as well.
GDF
Re: Getting xdata
« Reply #2 on: February 02, 2020, 01:06:33 PM »
Thanks Jeff
I uploaded a new drawing.
roy_043
  • BricsCAD 18
Re: Getting xdata
« Reply #3 on: February 02, 2020, 02:44:37 PM »
The entity does not have xdata for the "DRWDWLVR" application. You should improve your GET-XDATA-DRWDWLVR function: add a non-nil check for XDTYPE (or XDVALUE).
GDF
Re: Getting xdata
« Reply #4 on: February 02, 2020, 02:48:05 PM »
I have found the problem. I have done a major overhaul of the routine and have just found a typo in the ADD-XDATA-DRWDWLVR portion of the routine.
(regapp "DRWDWLVR") was misspelled.
Thanks Roy
;;;Peter Jamtgaard
(defun ADD-XDATA-DRWDWLVR  (/ ENAM EOBJ STR)
  (regapp "DRWDWLVR")
  (setq ENAM (cdar (entget (entlast)))
        STR  (rtos ARCH#ANGL 2 8))
  (vla-setxdata
    EOBJ
    (vlax-make-variant
      (vlax-safearray-fill
        (vlax-make-safearray vlax-vbInteger '(0 . 1))
        '(1001 1000)))
    (vlax-make-variant
        (vlax-make-safearray vlax-vbVariant '(0 . 1))
        (list "DRWDWLVR" STR))))
  (prin1))
« Last Edit: February 02, 2020, 03:01:27 PM by GDF »
dgorsman
Re: Getting xdata
« Reply #5 on: February 03, 2020, 05:09:12 PM »
Instead of a hard-coded string in multiple locations, create a global variable and reference that everywhere.  Easier to debug, fix, and modify.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
GDF
Re: Getting xdata
« Reply #6 on: February 03, 2020, 05:21:57 PM »
The routine is used in another routine to automatically install a door or window in a wall in plan, and later to rotate or mirror the block after insertion. It also automatically fills in the door or window tag by selecting the block.
