Poll
What does your AutoLisp programming directory look like?
One folder with many files/projects.
6 (50%)
A folder for each project.
6 (50%)
Total Members Voted: 12
Voting closed: February 09, 2020, 08:40:06 AM
Author Topic: What does your AutoLisp programming directory look like?  (Read 5328 times)
« on: January 30, 2020, 07:07:50 PM »
Do you have a folder with a bunch of different projects/files in it or do you like a folder for each different project?
Please share a description of how your programming directory looks like.
This poll will run for 10 days.
Re: What does your AutoLisp programming directory look like?
« Reply #1 on: January 30, 2020, 07:47:27 PM »
You didn't include a "Both" option, John. I don't have many 'projects' per se, with many files. I do have separate folders for plain Acad, Civil 3D, & Land Desktop tools. But, within each of those folders are a multitude of files, most of which don't rely on any others. Now, if I were still actually coding in lisp and creating Dialogs, I would likely go with the folder per project option.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #2 on: January 30, 2020, 08:42:03 PM »
A folder for each project. I use a local SVN
D:/Dev/Projects/...
« Reply #3 on: January 30, 2020, 09:22:40 PM »
... I use a local SVN
D:/Dev/Projects/...
*wow* SVN?! Now that's old-school!
« Reply #4 on: January 30, 2020, 09:34:38 PM »
I use a folder per project.
~/programming/<language>/projects/tools/<project>
It's Alive!
  • Retired
  • AKA Daniel
« Reply #5 on: January 30, 2020, 11:53:41 PM »
D:/Dev/Projects/...
Been using it for years, no reason to change as it has all the features I need
« Reply #6 on: January 31, 2020, 12:32:22 AM »
Can’t argue with that.
kpblc
« Reply #7 on: January 31, 2020, 03:05:09 AM »
One folder with many subfolders and files for each project. With git ;)
Sorry for my English.
VovKa
  • Ukraine
« Reply #8 on: January 31, 2020, 05:23:49 AM »
what is a 'project'?
tombu
  • ByLayer=>Not0
« Reply #9 on: January 31, 2020, 07:07:42 AM »
Glad I wasn't the first to post who didn't know what a lisp project was. Do you need to put every folder in the SFSP and Trusted Locations? What's the purpose?
For Civil 3D it makes sense to keep drawings and associated files in a project folder, but this is the first I've ever heard of an AutoLisp programming directory.
Tom Beauford P.S.M.
kpblc
« Reply #10 on: January 31, 2020, 07:25:27 AM »
Your daily job :)
What for? Before loading lisp turn off secureload system variable, and restore it after loading codes.
« Reply #11 on: January 31, 2020, 09:20:26 AM »
When you create a program to "Move all stuff to Layer X" (for example) you don't/didn't create a folder for that lisp file(s)?
« Reply #12 on: January 31, 2020, 09:21:54 AM »
That's interesting. One git repo and many projects?
« Reply #13 on: January 31, 2020, 09:38:10 AM »
I got out of AutoCAD and AutoLisp before trusted locations came about but apparently you can add an ellipsis after the path to include all sub-folders to the trusted locations.
C:\AutoLisp\Program\Directory\...
« Last Edit: January 31, 2020, 09:55:48 AM by John Kaul (Se7en) »
kpblc
« Reply #14 on: January 31, 2020, 10:31:36 AM »
No. one repo for one project.
