Author Topic: Autolisp was Ruined by Visual Lisp  (Read 3426 times)
Ben Clark
« on: January 24, 2020, 06:38:35 PM »
It's pretty clear that the arrival of Visual Lisp ruined Autolisp. Do you really want a bunch of drafters running around with the capability to manipulate all that Windows functionality through Active X? No one was sitting around asking for object oriented programming in AutoCAD's most popular API, but for some reason it was added. Me? I like a more pure form of programming that McCarthy originally envisioned when he axiomatized computation by creating lisp.
"Doesn't Visual Lisp add a rich library of additional list processing functions? Not just OOP?"
Yes. Well kind of. But those are part of what ruined autolisp as well. The entire IDEA of lisp is that you're creating your own language as you go. If you can't write vl-every, vl-some, and vl-sort in your sleep then you shouldn't be programming in autolisp anyway.
"You don't ever use functions written by others?"
No, I do not. I actually only program in the original 7 functions used by the first lisp interpreter and I build from there: quote, atom, eq, car, cdr, cons, and cond
"But that doesn't allow you to do arithmetic or even set variables."
Precisely. And that brings up another thing. Variables ruined autolisp as well. Lisp was originally a functional programming language. That was the focus. We didn't' need to convolute things by asking the computer to remember these arbitrarily named and ill-defined entities. Not to be overly rigorous, but what even is a variable? I will not entertain such a concept unless I have a rigorously defined way to construct it.
"No variables?? How do you write anything that has actual application?"
Who said anything about application? Unlike these simple-minded drafters, I think of Autolisp as more than just a convenient API for AutoCAD. In fact, I don't even use AutoCAD or do drafting of any kind. I simply found it to be a nice interpreter for lisp.
"Ok so you don't do any drafting, you don't use variables or arithmetic of any kind when programming, and you only use the original 7 functions from the first lisp interpreter. What then do you even use autolisp for?"
Recursion.
"Ok but I can't really think of a single useful thing you could do with just those functions and recursion. You haven't supported your point very well that Visual Lisp ruined Autolisp."
« Last Edit: January 24, 2020, 06:42:08 PM by Ben Clark »
Atook
  • AKA Tim
Re: Autolisp was Ruined by Visual Lisp
« Reply #1 on: January 24, 2020, 09:25:45 PM »
« Reply #2 on: January 24, 2020, 09:35:54 PM »
Long live xlisp! ...I have/had the source code to XLISP somewhere.
https://www.cs.cmu.edu/~rbd/doc/nyquist/part19.html
I'd be careful tossing around that OOP verbiage when you're talking about AutoLisp.
Actually, I think it was purchased (not created by Autodesk); it was before my time but I believe it was called VitalLisp.
'What is a variable?' ...haha. Yup.
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #3 on: January 25, 2020, 01:56:42 AM »
Yes John. Developed by Basis Software.
I was using the Basis build before the sale ... I think MP was also an early Basis user.
The Crime is that AutoDesk did not work on it other than to rebadge it ... what an incredible waste of potential.
https://www.cbronline.com/news/autodesk_buys_vital_lisp_tool/
As far as the OP is concerned ; I read the first sentance sentence and switched off.
« Last Edit: January 26, 2020, 04:15:51 PM by kdub »
Called Kerry in my other life
I live at UTC + 13.00
It's Alive!
  • Retired
  • AKA Daniel
« Reply #4 on: January 25, 2020, 04:29:45 AM »
LOL  :-D
« Reply #5 on: January 25, 2020, 10:29:46 AM »
It seems like they did the same thing with Lisp itself; they took an early build of XLisp, or whatever, and never updated it after it was implemented. They just left all the buggy/unfinished parts. Language parts missing and all.
The Crime is that AutoDesk did not work on it other than to rebadge it ... what an increadible waste of potential.
As far as the OP is concerned ; I read the first sentance and switched off.
« Reply #6 on: January 25, 2020, 10:55:56 AM »
Kerry pretty much addressed everything.
Ben Clark
« Reply #7 on: January 25, 2020, 12:03:03 PM »
I hope everyone can understand that this is a joke about recursion. Please read to the end.
The notion that vlisp ruined autolisp is too ridiculous to be real  :lol:
« Reply #8 on: January 25, 2020, 12:18:49 PM »
Needs more emojis.
« Reply #9 on: January 25, 2020, 01:21:50 PM »
BIGAL
  • 40 + years of using Autocad
« Reply #10 on: January 25, 2020, 10:28:39 PM »
Which came 1st Acet or VL ?
https://www.bricsys.com/bricscad/help/en_US/CurVer/DevRef/index.html?page=source%2FTX_01.htm
Go Lisp then go to express tools api
nobody
  • .net stuff
« Reply #11 on: January 26, 2020, 12:58:36 AM »
via Imgflip Meme Generator
Thank you Atook... my soul was is missing some futurama in it
