Author Topic: Unable to join lines with PEDIT  (Read 2982 times)
Vikram
« on: January 21, 2020, 03:25:35 AM »
I have a drawing in which I'm not able to join the lines. When I zoom it I see there is tiny gap between the lines but I'm not able to stretch it too.  How do I join the lines?
Reference drawing is attached
Marc'Antonio Alessi
  • Marco
Re: Unable to join lines with PEDIT
« Reply #1 on: January 21, 2020, 03:43:20 AM »
1 - Off the SNAP
2 - use (command "_.PEDIT" "_M" ...)   with precision distance
3 -  :)
Vikram
« Reply #2 on: January 21, 2020, 04:04:51 AM »
I tired that not working   :-(
The end points of the lines are not joined.See the drawing
Marc'Antonio Alessi
  • Marco
« Reply #3 on: January 21, 2020, 04:16:35 AM »
Comando: _PEDIT
Selezionare polilinea o [Multiplo]: _m
Selezionare oggetti: Specificare angolo opposto: trovato(i) 2
Digitare un'opzione [CHiudi/Apri/Unisci/Larghezza/ADatta/Spline/Rettifica/Tipolinea gen./Inverti/ANnulla]: _j
Tipo unione = Estendi
Digitare distanza approssimazione o [Tipo unione] <0.1000>:
2 segmenti aggiunti alla polilinea
DEVITG
« Reply #4 on: January 21, 2020, 07:50:48 AM »
I do not know why, but it can no be selected more than one entity .
as per the logfile you can sse it.
[ AutoCAD - Tue Jan 21 09:43:35 2020  ]----------------------------------------
Command: LOGFILEPATH
Enter new value for LOGFILEPATH, or . for none <"h:\">: *Cancel*
Command: *Cancel*
Command: LOGFILEON
Command:
Command:
Command: _pedit
Select polyline or [Multiple]:
Enter an option [Close/Join/Width/Edit vertex/Fit/Spline/Decurve/Ltype gen/Reverse/Undo]: J
Select objects: 1 found
Select objects:
0 segments added to polyline
Select objects: *Cancel*
Enter an option [Close/Join/Width/Edit vertex/Fit/Spline/Decurve/Ltype gen/Reverse/Undo]: *Cancel*
Command:
Command:
Command: _pedit
Select polyline or [Multiple]: m
Select objects: 1 found, 1 total
Select objects:
Enter an option [Close/Open/Join/Width/Fit/Spline/Decurve/Ltype gen/Reverse/Undo]: J
Join Type = Extend
Enter fuzz distance or [Jointype] <0.1000>:
Enter an option [Close/Open/Join/Width/Fit/Spline/Decurve/Ltype gen/Reverse/Undo]: C
Enter an option [Close/Open/Join/Width/Fit/Spline/Decurve/Ltype gen/Reverse/Undo]: *Cancel*
Command:
Command: _erase
Select objects:
Command: *Cancel*
Command: *Cancel*
Command: _.undo Current settings: Auto = On, Control = All, Combine = Yes, Layer = Yes
Enter the number of operations to undo or [Auto/Control/BEgin/End/Mark/Back] <1>: 1 ERASE GROUP
Command: *Cancel*
Command: *Cancel*
Enter the number of operations to undo or [Auto/Control/BEgin/End/Mark/Back] <1>: 1 Polyline Edit GROUP
Crossing Lasso  Press Spacebar to cycle options
Command: Specify opposite corner or [Fence/WPolygon/CPolygon]:
Command: *Cancel*
Command: *Cancel*
Command:
Command:
Command: _pedit
Select objects: all
3 found
Select objects:
Command: *Cancel*
Command: MPEDIT
Initializing...
Command: *Cancel*
Command:
Automatic save to C:\Program Files (x86)\AutoCAD 2008\Support\join seperated lines _1_27415_4764.sv$ ...
Command:
Command:
Command:
Command: _copy
Select objects: Specify opposite corner: 1 found
Command: LOGFILEOFF
roy_043
  • BricsCAD 18
« Reply #5 on: January 21, 2020, 07:54:11 AM »
@Vikram:
The issue may be that you are using IntelliCAD. Please consider adding this to your signature. It would prevent a lot of confusion.
DEVITG
« Reply #6 on: January 21, 2020, 08:02:04 AM »
After saved as acad 2018 , and using "all" a selection set , it join with a fuzze= 0.1 .
Marc'Antonio Alessi
  • Marco
« Reply #7 on: January 21, 2020, 08:12:24 AM »
1 - Off the SNAP
Vikram
« Reply #8 on: January 22, 2020, 02:05:00 AM »
Thanks for they help!
roy_43 I wish I could use Autocad but my company prefered Intellicad. I'm facing lot of problems due to no proper forum of Intellicad.
« Reply #9 on: January 22, 2020, 08:17:19 AM »
Please consider specifying that you are using Intellicad either in your forum signature as Roy as noted, or as part of your question when starting a new thread, as many solutions offered are not generally compatible across all CAD platforms and it will avoid a lot of unnecessary debugging by users attempting to help you with a solution which isn't compatible on your platform.
lee50310
  • Mosquito
« Reply #10 on: February 12, 2020, 11:50:36 AM »
Try this codes, he can meet your needs
https://drive.google.com/file/d/1W1qIRgkptZgRJBkiI2Jvx4690-P8-_Uj/view?usp=sharing
 (defun c:test (/ e ba bm bx ss kk pp)
             (setq os (getvar "osmode"))
             (setvar "osmode" 0)
             (setq ss (ssget))
             (setq i 0 )
     (repeat (sslength ss)
             (setq en (ssname ss  i))
             (setq e (cdr (assoc 0 (entget en))))
         (if (or (= e "ARC") (= e "LINE"))
             (setq bm (cons en bm))
             (setq bx (cons en bx))
             (setq i (+ i 1))
     (foreach x bm
             (vl-cmdf "_.pedit" "_m" x "" "_y" "")
             (setq ba (cons (entlast) ba))
             (setq kk (append bx ba ))
             (setq pp (ssadd))
             (mapcar  '(lambda (x) (setq pp (ssadd x pp) )) kk)
             (vl-cmdf "_.pedit" "_m" pp "" "_j" "3" "")
             (setvar "osmode" os)
« Last Edit: February 14, 2020, 10:39:31 PM by lee50310 »
