Author Topic: Map 3D - modifying strings in toolbar of forms?  (Read 3964 times)
Peter2
« on: January 08, 2020, 08:51:11 AM »
Map 2018, Industry Model, Oracle
I'm not very hopeful to get a solution, but nevertheless:
is there a (not too complicated) way to modify the strings which are displayed as tooltips in the forms? See attachment.
With Infrastructure Admin I can (de)activate them and get an "Info", but sometimes the strings are so inconsistent and confusing that I would like to modify them.
Peter
BricsCAD V23
Peter2
Re: Map 3D - modifying strings in toolbar of forms?
« Reply #1 on: January 09, 2020, 04:12:41 AM »
Additional infos:
I found the strings here (German version):
c:\Program Files\Autodesk\AutoCAD 2018\Map\bin\de-DE\Autodesk.Map.IM.Utilities.App.resources.dll
I tried to open it with current "Resourcehacker" http://www.angusj.com/resourcehacker/
but there I get only header information.
Can this DLL get modified by a non-programmer-user?
DLL-Info:
C:\Program Files\Autodesk\AutoCAD 2018\Map\bin\de-DE\Autodesk.Map.IM.Utilities.App.resources.dll
on x64 Professional Edition Version 10.0 (build 18362)
File Version Information :
Version language : Deutsch (Deutschland)
      Comments   :
      CompanyName   : Autodesk, Inc
      FileDescription   : Autodesk.Map.IM.Utilities.App
      FileVersion   : 21.0.015.11
      InternalName   : Autodesk.Map.IM.Utilities.App.dll
      LegalCopyright   : Copyright 2017 Autodesk, Inc. All rights reserved.
      LegalTrademarks   : Map 3D
      OriginalFilename   : Autodesk.Map.IM.Utilities.App.dll
      ProductName   : AutoCAD Map 3D
      ProductVersion   : 21.0.015.11
      Assembly Version   : 21.0.15.11
Creation Date   : 23/02/2017  10:53:56
Last Modif. Date   : 23/02/2017  10:53:56
Last Access Date   : 05/02/2019  10:46:48
FileSize   : 35536 bytes ( 34.703 KB,  0.034 MB )
FileVersionInfoSize   : 2116 bytes
File type   : Dynamic Link Library (0x2)
Target OS   : Win32 (0x4)
File/Product version   : 21.0.15.11 / 21.0.15.11
Language    : Deutsch (Deutschland) (0x407)
Character Set   : 1200 (ANSI - Unicode (BMP of ISO 10646)) (0x4B0)
Build Information :
Debug Version   : no
Patched Version   : no
Prerelease Version   : no
Private Version   : no
Special Build   : no
Peter
BricsCAD V23
