Author Topic: More dimscale please  (Read 7302 times)
jlogan02
« on: December 19, 2019, 07:17:55 PM »
How would I include a filter for text objects found on "X" layers located at pt1 and pt2?
  1. (defun c:foo4 ( / dim pt1 pt2)
  2.
  3.    pt1 '(33.375 21.4375);;revision text
  4.         pt2 '(31.875 5.3125);;revision text
  5. )
  6.
  7. (setq dim (getvar 'dimscale)
  8.         pt1 (mapcar '* pt1 (list dim dim))
  9.         pt2 (mapcar '* pt2 (list dim dim))
  10. )
  11.
  12. ;;need combine a filter for all TEXT layers with pt1 pt2
  13. ;;something like ????
  14. (setq rev1 (ssget "C" (list pt1 pt2) ((8 . "Text*")))
  15.
  16. (command "._change" rev1 "" "p" "la" "TBLK_TBLK_REVTEXT" "")
  17.
  18.   (princ)
  19. )
  20.
  21. )
J. Logan
ACAD 2018
I am one with the Force and the Force is with me.
AutoCAD Map 2018 Windows 10
ribarm
  • Marko Ribar, architect
Re: More dimscale please
« Reply #1 on: December 20, 2019, 08:31:38 AM »
  1. (defun c:foo4 ( / dim pt1 pt2 pt1n pt2n rev1 rev2 )
  2.
  3.   (setq
  4.      pt1 '(33.375 21.4375) ;;; revision text
  5.      pt2 '(31.875 5.3125) ;;; revision text
  6.   )
  7.   ;|
  8.   (setq dim (getvar 'dimscale)
  9.         pt1 (mapcar '* pt1 (list dim dim)) ;;; I am not sure what do you meant with this...
  10.         pt2 (mapcar '* pt2 (list dim dim)) ;;; I am not sure what do you meant with this...
  11.   )
  12.   |;
  13.   (setq dim (getvar 'dimscale)
  14.         pt1n (mapcar '+ pt1 (list dim dim)) ;;; Maybe this is what you wanted, but not sure either...
  15.         pt2n (mapcar '+ pt2 (list dim dim)) ;;; Maybe this is what you wanted, but not sure either...
  16.   )
  17.
  18.   (setq rev1 (ssget "_C" (list pt1 pt1n) '((0 . "*TEXT")))) ;;; first sel set with point pt1 (entities could be TEXT or MTEXT on any layer)
  19.   (setq rev2 (ssget "_C" (list pt2 pt2n) '((0 . "*TEXT")))) ;;; second sel set with point pt2 (entities could be TEXT or MTEXT on any layer)
  20.
  21.   (command "_.CHANGE" rev1 "" "_P" "_LA" "TBLK_TBLK_REVTEXT" "")
  22.   (command "_.CHANGE" rev2 "" "_P" "_LA" "TBLK_TBLK_REVTEXT" "")
  23.
  24.   (princ)
  25. )
  26.
« Last Edit: December 20, 2019, 08:34:42 AM by ribarm »
M.R. on Youtube
« Reply #2 on: December 20, 2019, 09:19:21 AM »
Remember too that these text objects need to be visible on the screen for this to work.
jlogan02
« Reply #3 on: December 20, 2019, 07:24:10 PM »
I see why that was confusing. I posted the wrong code.
This is what I currently us
  1. (if (and (= (getvar 'dimscale) 8)
  2.   (setq rev1 (ssget "c" '(268.5 171.0) '(254.25 42.125) '((8 . "Text*"))))
  3.   )
  4.    (command "._change" rev1 "" "p" "la" "TBLK_TBLK_REVTEXT" "")
  5.   (and (setq rev1 (ssget "c" '(33.375 21.4375) '(31.875 5.375) '((8 . "Text*"))))
  7.         )
  8. )
  9.
We use model space with multiple scaled title blocks. The above code demonstrates how I handle changes to the area specified by the ssget "c" in a
1 1/2" = 1'-0" drawing. If it's not a dimscale of 8 then it's got to be dimscale 1.0. For now I'm only addressing these two title blocks. I would like to expand that to address all 12 of our title blocks.
The code below is closer to what I have in mind.
  1.
  2.   (setq lst '((31.875 5.3125) (33.375 21.4375)))
  3.   (setq dim (getvar 'dimscale) lst (mapcar '(lambda (x) (mapcar '* x (list dim dim))) lst))
  4.   (setq rev1 (ssget (cons "_C" lst) '((8 . "TEXT*"))));;;my issue is here, I'm pretty sure. I just don't know why.
  5.
  6.   do stuff here....
  7.
  8.
J. Logan
ACAD 2018
jlogan02
« Reply #4 on: December 20, 2019, 07:26:01 PM »
Yes Ron. Thanks for that. I have that set in the larger code. Actually I think we may have discussed that in a prior post about roughly the same thing I'm trying to do here.
J. Logan
ACAD 2018
BIGAL
  • 40 + years of using Autocad
« Reply #5 on: December 20, 2019, 10:18:14 PM »
Change to layouts and all your title block problems will go away.
ribarm
« Reply #6 on: December 21, 2019, 05:30:38 AM »
  1.   ...
  2.   (setq rev1 (ssget (cons "_C" lst) '((8 . "TEXT*"))));;;my issue is here, I'm pretty sure. I just don't know why.
  3.
  4.   do stuff here....
  5.
  1.   ...
  2.   (setq rev1 (append (cons 'ssget (cons "_C" lst)) '(((8 . "TEXT*")))))
  3.
  5.
M.R. on Youtube
« Reply #7 on: December 21, 2019, 08:19:54 AM »
  1.   ...
  3.
  5.
  1.   ...
  3.
  5.
Or just:
  1. (setq rev1 (ssget "_C" lst '((8 . "TEXT*"))))
ribarm
« Reply #8 on: December 21, 2019, 08:31:51 AM »
Yes Lee, I haven't noticed that... It was already correctly posted before, but I was seduced by OP's code...
M.R. on Youtube
jlogan02
« Reply #9 on: December 24, 2019, 05:14:41 PM »
Here's the full code with Lee's last suggestion.
  1. (defun Rev_Up ( / DIM DIM1 OSM REV1 REV2 X)
  2.   (defun _addlayer (name color ltype plot)
  3.     (cond ((not (tblsearch "layer" name))
  4.            (entmakex (list '(0 . "LAYER")
  5.                            '(100 . "AcDbSymbolTableRecord")
  6.                            '(100 . "AcDbLayerTableRecord")
  7.                            '(70 . 0)
  8.                            (cons 2 name)
  9.                            (cons 62 color)
  10.                            (cons 6
  11.                                  (cond ((tblobjname "ltype" ltype))
  12.                                        ("continuous")
  13.                                  )
  14.                            )
  15.                            (cons 290 plot)
  16.                            ;;1 = plottable 0 = not=plottable
  17.                      )
  18.            )
  19.           )
  20.           ((tblobjname "layer" name))
  21.     )
  22.   )
  23.
  24.   (setvar 'osmode 0)
  25.   (setvar 'cmdecho 0)
  26.
  27.   (command "Zoom" "E")
  28.
  29.   (setq lst '((31.875 5.3125) (33.375 21.4375)))
  30.   (setq dim (getvar 'dimscale) lst (mapcar '(lambda (x) (mapcar '* x (list dim dim))) lst))
  31.   (setq rev1 (ssget "_C" lst '((8 . "TEXT2"))))
  32.
  33.   (_addlayer "TBLK_TBLK_REVTEXT" 3 "Continous" 1)
  34.   (_addlayer "TBLK_TBLK_REVLINES" 9 "Continous" 1)
  35.   (command "_.CHANGE" rev1 "" "_P" "_LA" "TBLK_TBLK_REVTEXT" "")
  36.
  37.   (setvar 'osmode 1)
  38.   (setvar 'cmdecho 1)
  39.
  40.   (princ)
  41. )
  42. (REV_UP)
When I run it through the vlide console...
  1. _$ (setq lst '((31.875 5.3125) (33.375 21.4375)))
  2. ((31.875 5.3125) (33.375 21.4375))
  3. _$ (setq dim (getvar 'dimscale) lst (mapcar '(lambda (x) (mapcar '* x (list dim dim))) lst))
  4. ((765.0 127.5) (801.0 514.5))
  5. _$ (setq rev1 (ssget "_C" lst '((8 . "TEXT2"))));;ichose to speicifically identify the layer I'm looking for.
  6.
  7. Error: too many arguments; warning: unwind skipped on hard error
I suspect I'm fat fingering something or not reading something correctly. My eyes are a bit tired today.
If I use...
  1. (setq rev1 (append (cons 'ssget (cons "_C" lst)) '(((8 . "TEXT*")))))
at the console, I get...
  5. _$ (setq rev1 (append (cons 'ssget (cons "_C" lst)) '(((8 . "TEXT2)))))
  6. (SSGET "_C" (765.0 127.5) (801.0 514.5) ((8 . "TEXT2")))
  7. _$ (_addlayer "TBLK_TBLK_REVTEXT" 3 "Continous" 1)
  8. <Entity name: 1b975c66980>
  9. _$ (_addlayer "TBLK_TBLK_REVLINES" 9 "Continous" 1)
  10. <Entity name: 1b975c66990>
  11. _$ (command "_.CHANGE" rev1 "" "_P" "_LA" "TBLK_TBLK_REVTEXT" "")
  12. nil
Yes!!! I've actually set up a meeting for the first of the year on this. This code is part of that. Moving objects from old drawings into the new Pspace title block. This code assists with that.
Happy Holidays to you all.
J. Logan
ACAD 2018
jlogan02
« Reply #10 on: January 06, 2020, 05:00:12 PM »
Getting back to this just now...I still haven't figure out why I'm getting... "too many arguments".
J. Logan
ACAD 2018
Dlanor
« Reply #11 on: January 07, 2020, 06:25:46 AM »
  7.                            '(70 . 0)
  8.                            (cons 2 name)
  9.                            (cons 62 color)
  10.                            (cons 6
  12.                                        ("continuous")
  13.                                  )
  14.                            )
  15.                            (cons 290 plot)
  17.                      )
  18.            )
  19.           )
  21.     )
  22.   )
This should probably be this (cons 6.....)
  7.                            '(70 . 0)
  8.                            (cons 2 name)
  9.                            (cons 62 color)
  10.                            (cons 6
  11.                                  (cond ((tblobjname "ltype" ltype) ltype)
  12.                                        ("continuous")
  13.                                  )
  14.                            )
  15.                            (cons 290 plot)
  17.                      )
  18.            )
  19.           )
  21.     )
  22.   )
  23.
as (tblobjname "ltype" ltype) returns an entity if true
You are masking it by passing in "continous" instead of "continuous" in some of your calls
snownut2
  • Bricscad 22 Ultimate
« Reply #12 on: January 07, 2020, 07:41:10 AM »
What is line 12?
("Continuous")
Looks like a function call.  No parentheses required.
« Reply #13 on: January 07, 2020, 08:13:31 AM »
What is line 12?
("Continuous")
Note that it's not a function call, but rather a cond condition, returning a literal string.
jlogan02
« Reply #14 on: January 07, 2020, 04:55:14 PM »
Thanks for that.
However, your catch didn't solve that problem.
  4. ((31.875 5.3125) (33.375 21.4375))
  5. _$ (setq rev1 (ssget "_C" lst '((8 . "TEXT2"))));;shouldn't I be getting the selected entities after this?
<selection set: ????;;;instead I'm getting too many arguments
I've literally stripped the code down to just the guts and...nothing. This is getting aggravating.
J. Logan
ACAD 2018
