Author Topic: Hyperlinks with Commands?  (Read 1877 times)
MSTG007
« on: December 19, 2019, 03:57:27 PM »
This is another off the wall question.
I know you can attach a hyperlink to an object or text. Select the control button and then the object to launch it.
Is there anyway to do the same except have it run an autocad command?
Civil3D 2020
Re: Hyperlinks with Commands?
« Reply #1 on: December 19, 2019, 04:22:32 PM »
Not that I'm aware of .... why would you want to do this?
MSTG007
« Reply #2 on: December 19, 2019, 04:46:35 PM »
Here is my example. I have a title sheet or cover sheet. In certain areas of that sheet, a certain command would be needed.
For example. There would be a box or border for a location map. I could click that object which would run the command that would turn on autocad geolocation map.
That’s why I thought it was an off the wall question, but an interesting idea.
Civil3D 2020
Rod
« Reply #3 on: December 19, 2019, 08:19:28 PM »
A custom command that runs on a double click action would be your best bet.
If the block is a certain name then run command
otherwise do the normal double click action
"All models are wrong, some models are useful" - George Box
