Is there a way to implement a selectionfilter based on the circle's center coordinate with C# like one of the criteria in FILTER command?
Let say I want to select the circles with the center X>=0 and Y>=0 and Z=0.
With the following code it can create a filter to select the circles with radius >=10.0.
But I can not find a way to implement the filter based on circle's center coordinate.
Is that possible to do so?
TypedValue[] Arr = new TypedValue[]
new TypedValue((int)DxfCode.Start, "CIRCLE"),
new TypedValue((int)DxfCode.Operator, ">="),
new TypedValue((int)DxfCode.Real, 10.0),
Thanks!
