Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
how to call function and store output in variable ?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: how to call function and store output in variable ? (Read 1519 times)
vincent.r
Newt
on:
December 09, 2019, 05:41:14 AM »
I made a function to get list of electrical connection data to block. List consist of sub lists of tag, attribute value & insertion point.
Final output stored in variable "masterconnectiondata". Function performs fine.
I am trying to call this function from another program
Code - Auto/Visual Lisp:
[Select]
setq
masterconnectiondata1
vr:checkconnectionpoints sortedlist2
but not able to store data in variable masterconnectiondata1.
Am I made mistake somewhere ?
code -
[Select]
defun
sortedlist1
dataextractfi1 dataextractatt1 dataextractattval1 dataextracttagval1 dataextractinsval1 connectionpointlist connectionlist
while
length
sortedlist1
0
setq
dataextractfi1
car
sortedlist1
setq
dataextractatt1
entnext
dataextractfi1
while
cdr
assoc
0
entget
dataextractatt1
"SEQEND"
setq
dataextractattval1
cdr
assoc
1
entget
dataextractatt1
setq
dataextracttagval1
cdr
assoc
2
entget
dataextractatt1
setq
dataextractinsval1
cdr
assoc
10
entget
dataextractatt1
;(SETQ dataextracttagval1 "X4TERMDESC01")
if
and
setq
x4testpoint
vl-string-search
"X4TERM"
dataextracttagval1
0
vl-string-search
"DESC"
dataextracttagval1
nil
progn
setq
connectionpointlist
cons
dataextracttagval1 connectionpointlist
setq
connectionpointlist
cons
dataextractattval1 connectionpointlist
setq
connectionpointlist
cons
setq
connectionpointlist
reverse
connectionpointlist
setq
connectionlist
cons
;(setq connectionlist nil)
setq
connectionpointlist
nil
setq
dataextractatt1
entnext
dataextractatt1
setq
cons
connectionlist masterconnectiondata
setq
connectionlist
nil
setq
sortedlist1
cdr
sortedlist1
EDIT (John): Added code tags.
Last Edit: December 09, 2019, 11:55:15 AM by John Kaul (Se7en)
Logged
ribarm
Gator
Marko Ribar, architect
WWW
Re: how to call function and store output in variable ?
Reply #1 on:
December 09, 2019, 05:57:34 AM »
masterconnectiondata variable must be last statement before ending closing bracked of zour sub function... It should also be localized among other localized variables...
Logged
Marko Ribar, d.i.a.
(graduated engineer of architecture)
M.R. on Youtube
vincent.r
Newt
Reply #2 on:
December 09, 2019, 06:38:15 AM »
Thanks for efforts ribarm !
Tried your suggestion. But it doesn't work. It gives nil output.
Modifies code is -
[Select]
defun
sortedlist1
dataextractfi1 dataextractatt1 dataextractattval1 dataextracttagval1 dataextractinsval1 connectionpointlist connectionlist masterconnectiondata masterconnectiondataresult
while
length
sortedlist1
0
setq
dataextractfi1
car
sortedlist1
setq
dataextractatt1
entnext
dataextractfi1
while
cdr
assoc
0
entget
dataextractatt1
"SEQEND"
setq
dataextractattval1
cdr
assoc
1
entget
dataextractatt1
setq
dataextracttagval1
cdr
assoc
2
entget
dataextractatt1
setq
dataextractinsval1
cdr
assoc
10
entget
dataextractatt1
if
and
setq
x4testpoint
vl-string-search
"X4TERM"
dataextracttagval1
0
vl-string-search
"DESC"
dataextracttagval1
nil
progn
setq
connectionpointlist
cons
setq
connectionpointlist
cons
setq
connectionpointlist
cons
setq
connectionpointlist
reverse
connectionpointlist
setq
connectionlist
cons
setq
connectionpointlist
nil
setq
dataextractatt1
entnext
dataextractatt1
setq
connectionlist
nil
setq
sortedlist1
cdr
sortedlist1
setq
cons
setq
masterconnectiondataresult masterconnectiondata
Last Edit: December 09, 2019, 11:55:42 AM by John Kaul (Se7en)
Logged
Seagull
London, England
WWW
Reply #3 on:
December 09, 2019, 06:56:22 AM »
Amongst other issues, you are setting the data you have collected to nil before constructing the output list -
[Select]
setq
connectionlist
nil
;; <----- connectionlist is now nil
setq
sortedlist1
cdr
sortedlist1
setq
cons
;; <----- masterconnectiondata will be a list of nils
Logged
Lee Mac Programming
Twitter
Exchange App Store
vincent.r
Newt
Reply #4 on:
December 09, 2019, 07:12:38 AM »
Oh! my mistake. Thank you Lisp Master.
Thanks for efforts.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
