Author Topic: entmake list of layers, locking one layer in the list  (Read 2952 times)
jlogan02
« on: December 02, 2019, 07:00:08 PM »
How do I set one of several layers locked.
  1. (defun _addlayer (name color ltype plot)
  2.     (cond ((not (tblsearch "layer" name))
  3.            (entmakex (list '(0 . "LAYER")
  4.                            '(100 . "AcDbSymbolTableRecord")
  5.                            '(100 . "AcDbLayerTableRecord")
  6.                            '(70 . 0) ;;;referencing group code 70 here. The flag for a locked layer is 4.
  7.                            (cons 2 name)
  8.                            (cons 62 color)
  9.                            (cons 70 flag);; add element to list
  10.                            (cons 6
  11.                                  (cond ((tblobjname "ltype" ltype))
  12.                                        ("continuous")
  13.                                  )
  14.                            )
  15.                            (cons 290 plot)
  16.                            ;;1 = plottable 0 = not=plottable
  17.                      );; end list
  18.             );; end entmake
  19.           );; tblsearch
  20.           ((tblobjname "layer" name))
  21.     );; cond
  22.   );;   end _addlayer
  23.
  24. (_addlayer "layername" 1 4 "continous" 1) ;;indicate flag as 4
  25.
  26. )
  27.
This doesn't seem to work.
J. Logan
ACAD 2018
I am one with the Force and the Force is with me.
AutoCAD Map 2018 Windows 10
stevej
Re: entmake list of layers, locking one layer in the list
« Reply #1 on: December 02, 2019, 08:53:08 PM »
Example: To lock and freeze the grid and mark layers (if you're not averse to using "command"):
(command "_.-Layer" "lock" "grid,mark" "freeze" "grid,mark" "")
Separate layer names with commas and no spaces.
Steve
« Last Edit: December 02, 2019, 08:58:26 PM by stevej »
kpblc
« Reply #2 on: December 02, 2019, 11:56:10 PM »
Another one:
  1. (defun t1 (/ adoc)
  2.   (foreach item '("layer1" "layer2" "layer3")
  3.     (vl-catch-all-apply
  4.       (function (lambda () (vla-put-lock (vla-item (vla-get-layers adoc) item) :vlax-true)))
  5.       ) ;_ end of vl-catch-all-apply
  6.     ) ;_ end of foreach
  7.   (vla-endundomark adoc)
  8.   ) ;_ end of defun
Sorry for my English.
Dlanor
« Reply #3 on: December 03, 2019, 02:52:53 AM »
Maybe
  1. (defun _addlayer (name color flag ltype plot)
  6.                            (if (> flag 0) (cons 70 flag)  '(70 . 0)) ;;;referencing group code 70 here. The flag for a locked layer is 4.
  7.                            (cons 2 name)
  8.                            (cons 62 color)
  9.                            (cons 6
  10.                                  (cond ((tblobjname "ltype" ltype))
  11.                                        ("continuous")
  12.                                  )
  13.                            )
  14.                            (cons 290 plot)
  15.                            ;;1 = plottable 0 = not=plottable
  16.                      );; end list
  17.             );; end entmake
  18.           );; tblsearch
  19.           ((tblobjname "layer" name))
  20.     );; cond
  21.   );;   end _addlayer
  22.
  23. (_addlayer "layername" 1 4 "continous" 1) ;;indicate flag as 4
  24.
  25. )
  26.
« Last Edit: December 03, 2019, 02:56:18 AM by Dlanor »
tombu
  • ByLayer=>Not0
« Reply #4 on: December 03, 2019, 07:24:29 AM »
Creating Layer State las files that can easily be imported into any drawing or template is another option. They can be applied to a Viewport to create overrides as well. They can also be imported from DWG's, DWT's & DWS's.
Tom Beauford P.S.M.
jlogan02
« Reply #5 on: December 03, 2019, 11:29:52 AM »
Went briefly through my mind. Will test this.
  1. IF...
Maybe
  7.                            (cons 2 name)
  8.                            (cons 62 color)
  9.                            (cons 6
  11.                                        ("continuous")
  12.                                  )
  13.                            )
  14.                            (cons 290 plot)
  16.                      );; end list
  17.             );; end entmake
  18.           );; tblsearch
  20.     );; cond
  22.
  24.
  25. )
  26.
Currently what I'm doing.
Steve
Considered this early on but went with the command option. This method seemed a lil overkill for just locking a layer
Another one:
Have never looked into Layer State Las files. Thanks for the idea
Thanks for all the ideas folks. Much appreciated.
J. Logan
ACAD 2018
