Author Topic: Determine Nth Sector {Challenge}  (Read 4055 times)
Grrr1337
« on: November 15, 2019, 07:10:20 AM »
Hi guys,
This thread is an extension to my previous one (Determine quadrant - cursor),
Its very similar to it, but the current task is more like of a challenge - so I've decided a separate thread is worth for it -
---{Challenge}---
Write a (foo p1 p2 p3 n), where:
p1 - first specified point
p2 - second specified point
p3 - point to determine its sector location (assuming p3 its the cursor location)
n - amount of quadrants, their origin is (mid p1 p2), and oriented from p1-p2 vector
Exprected return rtn would be an integer that specifies the position of the nth sector the p3 is located at.
i.e.:
for n=2, rtn will have 2 possibilities (0, 1)
for n=3, rtn will have 3 possibilities (0, 1, 2)
for n=4, rtn will have 4 possibilities (0, 1, 2, 3)
for n=12, rtn will have 12 possibilities (0, 1, 2, 3... 11)
To clarify the above I wrote - check the demo .gif below.
Heres my try at it (although its very buggy) -
  1. (defun C:test ( / findrange GetQuadrants p1 p2 a n m spc mtxt textviewsize aL rL )
  2.
  3.
  4.   ;|
  5.   (findrange 34
  6.     '(
  7.       ( (1 10) "A")
  8.       ( (10 20) "B")
  9.       ( (20 30) "C")
  10.       (nil "D")
  11.     )
  12.   )
  13.   >> "D"
  14.
  15.   _$ (findrange -15
  16.     '(
  17.       ((nil 30) "I'm below or equal to thirty")
  18.       ((40 nil) "I'm above or equal to forty")
  19.       (nil "I'm something else, in this case between 30-40 (exclusive)")
  20.     )
  21.   )
  22.   >> "I'm below or equal to thirty"
  23.   |;
  24.   (setq findrange
  25.     (lambda (v L)
  26.       (if (and (numberp v) (listp L))
  27.         (vl-some
  28.           '(lambda (x / mn mx)
  29.             (setq mn (caar x))
  30.             (setq mx (cadar x))
  31.             (if (apply '<= (append (if mn (list mn)) (list v) (if mx (list mx)) ))
  32.               (cadr x)
  33.             ); if
  34.           ); lambda
  35.           L
  36.         ); vl-some
  37.       ); if
  38.     ); lambda (v L)
  39.   ); setq findrange
  40.
  41.   (setq GetQuadrants
  42.     (lambda ( p1 p2 n / a ainc tmp L )
  43.       (setq a (angle p1 p2))
  44.       (setq a (rem a PI))
  45.       (setq ainc (/ (* 2. PI) n))
  46.       (setq tmp ainc)
  47.       (while (<= tmp (* 2. PI))
  48.         (setq L (cons tmp L))
  49.         (setq tmp (+ tmp ainc))
  50.       )
  51.       (mapcar '(lambda (x) (+ x a)) (reverse L))
  52.     )
  53.   ); setq GetQuadrants
  54.
  55.
  56.
  57.   (if
  58.     (and
  59.       (setq p1 (getpoint "\nSpecify first point: "))
  60.       (setq p2 (getpoint p1 "\nSpecify second point: "))
  61.       (setq a (angle p1 p2))
  62.       (setq n
  63.         (
  64.           (lambda ( f ) (f nil))
  65.           (lambda ( n )
  66.             (initget (+ 2 4))
  67.             (cond
  68.               ( (= 1 (setq n (getint "\nSpecify amount of quadrants <2>: ")))
  69.                 (prompt "\n*Atleast 2 quadrants are allowed*") (f nil)
  70.               )
  71.               (n)(2)
  72.             )
  73.           )
  74.         )
  75.       )
  76.       (setq m (mapcar '(lambda ( a b ) (/ (+ a b) 2.0)) p1 p2 ))
  77.       (setq aL (GetQuadrants p1 p2 n))
  78.
  79.     ); and
  80.     (progn
  81.       (setq textviewsize (lambda nil (* (getvar 'textsize) (getvar 'viewsize) 0.005)))
  82.       (setq mtxt (vlax-invoke spc 'AddMtext '(0. 0. 0.) (textviewsize) "X"))
  83.       (vlax-put mtxt 'AttachmentPoint acAttachmentPointMiddleCenter)
  84.       (foreach x aL
  85.         (setq rL (cons (vlax-invoke spc 'AddRay m (polar m x (distance p1 p2))) rL))
  86.       )
  87.
  88.       (
  89.         (lambda ( / s k v )
  90.           (while (not s)
  91.             (mapcar 'set '(k v) (grread t))
  92.             (and (or (= k 25) (equal '(2 13) (list k v))) (setq s t))
  93.             (and
  94.               (= 5 k)
  95.               (progn
  96.                 (vlax-put mtxt 'InsertionPoint v)
  97.                 (vlax-put mtxt 'Height (textviewsize))
  98.                 (vlax-put mtxt 'TextString
  99.                   (vl-prin1-to-string
  100.                     (findrange
  101.                       (angle m v)
  102.                       (
  103.                         (lambda ( L / i r )
  104.                           (setq i -1)
  105.                           (setq r
  106.                             (mapcar '(lambda (a b) (list (list a b) (setq i (1+ i)))) (cons nil L) (cons (car L) (cdr L)))
  107.                           )
  108.                           (setq r (cons (list (list nil (car L)) (last (last r))) r))
  109.                           (setq r (append r '((nil ?))))
  110.                         )
  111.                         (cons a aL)
  112.                       )
  113.                     )
  114.                   )
  115.                 )
  116.                 t
  117.               ); progn
  118.             )
  119.           ); while
  120.         ); lambda
  121.       )
  122.       (foreach x (cons mtxt rL)
  123.         (vl-catch-all-apply (function vla-Delete) (list x))
  124.       )
  125.
  126.     ); progn
  127.   ); if
  128.   (princ)
  129. ); defun
« Last Edit: November 15, 2019, 11:54:01 AM by Grrr1337 »
(apply ''((a b c)(a b c))
vevo.bg
VovKa
  • Ukraine
Re: Determine Nth Quadrant {Challenge}
« Reply #1 on: November 15, 2019, 07:43:39 AM »
(1+ (fix (/ (vk_GetLeftAngle p3 (vk_GetMidPoint p1 p2) p2) (/ pi 0.5 n))))
ribarm
  • Marko Ribar, architect
« Reply #2 on: November 15, 2019, 10:02:25 AM »
Very nice and fast...
I widen your expression :
  1. (defun c:sectors ( / 3pang p1 p2 m n a k gr p3 el txt txte txtel f )
  2.
  3.   (defun 3pang ( ps po pe / a1 a2 )
  4.     (setq a1 (angle po ps))
  5.     (setq a2 (angle po pe))
  6.     (if (> a1 a2)
  7.       (+ (- (* 2 pi) a1) a2)
  8.       (- a2 a1)
  9.     )
  10.   )
  11.
  12.   (initget 1)
  13.   (setq p1 (getpoint "\nStart direction point : "))
  14.   (initget 1)
  15.   (setq p2 (getpoint p1 "\nEnd direction point : "))
  16.   (setq m (mapcar '(lambda ( a b ) (/ (+ a b) 2.0)) p1 p2))
  17.   (initget 1)
  18.   (setq n (getint "\nNumber of sectors : "))
  19.   (setq a (/ pi 0.5 n))
  20.   (setq k -1)
  21.   (repeat n
  22.     (setq el (cons (entmakex (list '(0 . "RAY") '(100 . "AcDbEntity") '(100 . "AcDbRay") (cons 10 m) (cons 11 (polar '(0.0 0.0 0.0) (+ (* (setq k (1+ k)) a) (angle m p2)) 1.0)))) el))
  23.   )
  24.   (while (= 5 (car (setq gr (grread t))))
  25.     (setq f nil)
  26.     (setq p3 (cadr gr))
  27.     (setq txt (1+ (fix (/ (3pang p2 m p3) a))))
  28.     (if (null txte)
  29.       (setq txte (entmakex (list '(0 . "TEXT") (cons 10 p3) (cons 40 (* 50 (/ (getvar 'viewsize) (cadr (getvar 'screensize))))) (cons 1 (itoa txt)))))
  30.       (progn
  31.         (if (not (equal p3 (cdr (assoc 10 txtel)) 1e-15))
  32.           (setq txtel (subst (cons 10 p3) (assoc 10 txtel) txtel) f t)
  33.         )
  34.         (if (/= txt (atoi (cdr (assoc 1 txtel))))
  35.           (setq txtel (subst (cons 1 (itoa txt)) (assoc 1 txtel) txtel) f t)
  36.         )
  37.         (if f
  38.           (entupd (cdr (assoc -1 (entmod txtel))))
  39.         )
  40.       )
  41.     )
  42.     (if (null txtel)
  43.       (setq txtel (entget txte))
  44.     )
  45.   )
  46.   (foreach e el
  47.     (if (and e (not (vlax-erased-p e)))
  48.       (entdel e)
  49.     )
  50.   )
  51.   (if (and txte (not (vlax-erased-p txte)))
  52.     (entdel txte)
  53.   )
  54.   (princ)
  55. )
  56.
« Last Edit: November 15, 2019, 04:01:47 PM by ribarm »
M.R. on Youtube
Grrr1337
« Reply #3 on: November 15, 2019, 11:32:54 AM »
Looks like you've won this one, VoVka!  :-D
I've also wrapped it into a sub:
  1. ; https://www.theswamp.org/index.php?topic=55573.msg597194#msg597194
  2. ; VoVka
  3. (defun foo ( p1 p2 p3 n )
  4.   (1+
  5.     (fix
  6.       (/
  7.         (
  8.           (lambda (p1 p2 p3 / Ang) ; vk_GetLeftAngle
  9.             (if (minusp (setq Ang (rem (+ pi (angle p2 p1) (- (angle p3 p2))) (* pi 2.0))))
  10.               (+ pi pi Ang)
  11.               Ang
  12.             )
  13.           )
  14.           p3
  15.           (mapcar '(lambda (a b) (* 0.5 (+ a b))) p1 p2)
  16.           p2
  17.         )
  18.         (/ PI 0.5 n)
  19.       )
  20.     )
  21.   )
  22. ); defun foo
  23.
  24.
  25. ; Test function
  26. (defun C:test ( / p1 p2 n spc )
  27.   (if
  28.     (and
  29.       (setq p1 (getpoint "\nSpecify first point: "))
  30.       (setq p2 (getpoint p1 "\nSpecify second point: "))
  31.       (setq n
  32.         ( (lambda ( f ) (f nil))
  33.           (lambda ( n )
  34.             (initget (+ 2 4))
  35.             (cond
  36.               ( (= 1 (setq n (getint "\nSpecify amount of quadrants <2>: ")))
  37.                 (prompt "\n*Atleast 2 quadrants are allowed*") (f nil)
  38.               )
  39.               (n)(2)
  40.             )
  41.           )
  42.         )
  43.       ); setq n
  44.     ); and
  45.     (
  46.       (lambda ( / m GetQuadrants spc textviewsize mtxt aL rL s k v )
  47.
  48.         (setq m (mapcar '(lambda ( a b ) (/ (+ a b) 2.0)) p1 p2 ))
  49.
  50.         (setq GetQuadrants
  51.           (lambda ( p1 p2 n / a ainc tmp L )
  52.             (setq a (abs (angle p1 p2)))
  53.             (setq ainc (/ (* 2.0 PI) n))
  54.             (setq tmp ainc)
  55.             (repeat n
  56.               (setq L (cons (setq tmp (+ tmp ainc)) L))
  57.             )
  58.             (mapcar '(lambda (x) (+ x a)) (reverse L))
  59.           )
  60.         ); setq GetQuadrants
  61.
  62.         (setq textviewsize (lambda nil (* (getvar 'textsize) (getvar 'viewsize) 0.005)))
  63.         (setq mtxt (vlax-invoke spc 'AddMtext '(0. 0. 0.) (textviewsize) "X"))
  64.         (vlax-put mtxt 'AttachmentPoint acAttachmentPointMiddleCenter)
  65.         (foreach x (setq aL (GetQuadrants p1 p2 n))
  66.           (setq rL (cons (vlax-invoke spc 'AddRay m (polar m x (distance p1 p2))) rL))
  67.         )
  68.         (while (not s)
  69.           (mapcar 'set '(k v) (grread t))
  70.           (and (or (= k 25) (equal '(2 13) (list k v))) (setq s t))
  71.           (and
  72.             (= 5 k)
  73.             (progn
  74.               (vlax-put mtxt 'InsertionPoint v)
  75.               (vlax-put mtxt 'Height (textviewsize))
  76.               (vlax-put mtxt 'TextString (vl-prin1-to-string (foo p1 p2 v n)))
  77.               t
  78.             ); progn
  79.           )
  80.         ); while
  81.         (foreach x (cons mtxt rL)
  82.           (vl-catch-all-apply (function vla-Delete) (list x))
  83.         )
  84.       ); lambda
  85.     )
  86.
  87.   ); if
  88.   (princ)
  89. ); defun
vevo.bg
ribarm
« Reply #4 on: November 15, 2019, 11:47:27 AM »
I just wanted to say that rather than term "quadrant" which express 4 areas of Decart cartesian coordinate system, better word is "sector" - area of plane between 2 rays described with some angle that those rays form with their origin as center of that planar coordinate system (plane)...
M.R. on Youtube
Grrr1337
Re: Determine Nth Sector {Challenge}
« Reply #5 on: November 15, 2019, 12:00:20 PM »
@Marko you are right -
I misled myself from my previous thread, by thinking about this even more generic modification to the sub.
Corrected the thread's title.
:thumbsup:
vevo.bg
VovKa
  • Ukraine
« Reply #6 on: November 15, 2019, 02:36:29 PM »
looks like i was the only one who participated
yeah, i took first places from both the top and the bottom  8-)
Grrr1337
« Reply #7 on: November 16, 2019, 07:24:58 AM »
It got me confused  - I find this task too difficult for me (although my math lacks), hence considered it as a challenge..
.. but your fast and short reply make it seem like answering to a request.  :-o
vevo.bg
VovKa
  • Ukraine
« Reply #8 on: November 16, 2019, 12:23:55 PM »
if i knew English better i'd definitely have written much longer posts ;)
martinle
« Reply #9 on: November 17, 2019, 11:53:32 PM »
Hello Mr. Ribarm,
Impressive example! To apply this example in everyday life I had the following idea assuming that Lisp would work in UCS:
A reactor that does the following:
When starting the command:
- Save the sector number globally
- save a separate UCS in each sector.
Result: As soon as one leaves the sector with the mouse the UCS is changed over.
That would be a great Lisp and would benefit many!
Greetings Martin
