Hi.
I'd like to modify my lisp. (Thanks Lee mac!)
It adds a point to object.
but It is uncomfortable to be able to add a point just ONE TIME.
Is it possible to modify for adding multiple points continually?
;;----------------=={ Add LWPolyline Vertex }==---------------;;
;; Adds a new vertex to an LWPolyline at a point specified ;;
;; by the user; compatible with LWPolylines at any ;;
;; orientation, with varying width and arc segments. ;;
;; Author: Lee Mac, Copyright ?2012 - www.lee-mac.com ;;
;; Version 1.0 - 17-12-2012 ;;
;; First release. ;;
(defun c:QQ ( / a b e h l n p r w x z )
(while
(progn (setq p (getpoint "\nPick Point for New Vertex: "))
( (null p) nil)
( (null (setq e (nentselp p)))
(princ "\nPoint does not lie on an LWPolyline.")
( (= 4 (length e))
(princ "\nObject is Nested.")
( (/= "LWPOLYLINE" (cdr (assoc 0 (entget (setq e (car e))))))
(princ "\nObject is not an LWPolyline.")
(if (and p e
(setq p (vlax-curve-getclosestpointto e (trans p 1 0))
n (vlax-curve-getparamatpoint e p)
(if (not (equal n (fix n) 1e-8))
(setq e (entget e)
h (reverse (member (assoc 39 e) (reverse e)))
l (LM:LWVertices e)
z (assoc 210 e)
(repeat (fix n)
(setq a (cons (car l) a)
l (cdr l)
(setq x (car l)
r (- n (fix n))
w (cdr (assoc 40 x))
w (+ w (* r (- (cdr (assoc 41 x)) w)))
b (atan (cdr (assoc 42 x)))
(entmod
(append h
(apply 'append (reverse a))
(list
(assoc 10 x)
(assoc 40 x)
(cons 41 w)
(cons 42 (tan (* r b)))
(list
(cons 10 (trans p 0 (cdr z)))
(cons 40 w)
(assoc 41 x)
(cons 42 (tan (* (- 1.0 r) b)))
(apply 'append (cdr l))
(list z)
;; Tangent - Lee Mac
;; Args: x - real
(defun tan ( x )
(if (not (equal 0.0 (cos x) 1e-10))
(/ (sin x) (cos x))
;; LW Vertices - Lee Mac
;; Returns a list of lists in which each sublist describes
;; the position, starting width, ending width and bulge of the
;; vertex of a supplied LWPolyline
(defun LM:LWVertices ( e )
(if (setq e (member (assoc 10 e) e))
(cons
(list
(assoc 10 e)
(assoc 40 e)
(assoc 41 e)
(assoc 42 e)
(LM:LWVertices (cdr e))
(vl-load-com) (princ)
;; End of File ;;
