Author Topic: Lee Mac's Random Number Generator Will Expire  (Read 4108 times)
Ben Clark
« on: November 14, 2019, 11:29:11 AM »
There's an urgent problem with Lee Mac's random number generator
http://www.lee-mac.com/random.html
It's of utmost importance because many of us use it in our applications. You see, his generator is a linear congruential generator with a seed, modulus, multiplier, and increment. The algorithm requires that the seed always be smaller than the modulus. If it's not, the whole process does not work.
Lee's seed is the Modified Julian Date (MJD) extracted by the AutoCAD "Date" system variable. His modulus is 4294967296, the largest number that can be represented with 32 bits. Which, if we hadn't been using MJD but rather UNIX time, we'd be here talking about the year 2038 problem and how that would be when his generator stopped working.
But my concern is this: since the seed is the Julian date, on December 14, 11,754,508 AD Lee's random number generator will stop working. And I for one don't want to be caught off guard and have my users not receive a randomly generated good morning message when they boot up AutoCAD.
Just thought I should bring this issue to the light.
Re: Lee Mac's Random Number Generator Will Expire
« Reply #1 on: November 14, 2019, 11:42:35 AM »
*blink-blink* ...Do you have a replacement in mind?
A friend of mine had a passion about random numbers and he was a lot of fun to talk to about the subject. He turned me on to an alternate generator I ended up using in a few programs of mine. The method is called the Mersenne Twister and it is used in quite a bit of code you use everyday.
https://en.wikipedia.org/wiki/Mersenne_Twister
Here is some code I posted (sorry, it's C) which you can preview.
http://www.theswamp.org/index.php?topic=41820.msg469410#msg469410
Dlanor
« Reply #2 on: November 14, 2019, 12:12:51 PM »
 :evillaugh: You've thwarted his evil plan. At least we've got a bit of time to come up with an alternative. :gum:
« Reply #3 on: November 14, 2019, 12:36:41 PM »
I wrote this *forever* ago; dunno when. The implementation simple, distribution reasonable, good enough for my needs.
(defun random ( )
    ;;  return real between 0 and 1
    (defun random ( )
        (setq *random*
            (   (lambda ( x ) (- x (fix x)))
                (expt (+ pi *random*) (+ 5 *random*))
    (setq *random*
            (expt (+ pi (/ 1.0 (getvar 'millisecs))) (rem (getvar 'millisecs) pi))
    (setq x 0)
    (repeat (setq n 10000) (setq x (+ x (random))))
    (print (/ x n))
>> 0.502127
FWIW ... cheers.
Ben Clark
« Reply #4 on: November 14, 2019, 02:15:23 PM »
Thanks John and MP for your additional methods. It's interesting to know there are so many ways to do it.
I hope my sarcasm was detected. I'm not actually concerned about anything that goes on 11 million years from now  :laugh:
« Reply #5 on: November 14, 2019, 02:33:47 PM »
I had glanced at your post and saw "2038 problem", figuring that was the gist of it. Reading it (now) verbatim it's funny as h3ll. :D tl;dr: Should have assumed Lee's function was impenetrable to anything a Klingon might throw at it.
« Reply #6 on: November 14, 2019, 03:01:35 PM »
> Additional methods
No problem. And, if you care to venture down the rabbit hole you could really have quite a bit of fun. For example, "when a RNG will stop working" isn't really a large issue; the fun begins when you start to research/get introduced to the Monte Carlo method. If you've had any formal programming education you may recognize that term--because it's been around forever--but here was a snip I saved in some random number notes of mine. This may have been snipped from the SICP book--which a lot of my lisp notes were--but it gives a good primer on the subject.
The Monte Carlo solution is/has been used in a wide range of stuff ranging from banking to automated car driving.
3.1.2  The Benefits of Introducing Assignment
As we shall see, introducing assignment into our programming language leads us into a thicket of difficult conceptual issues. Nevertheless, viewing systems as collections of objects with local state is a powerful technique for maintaining a modular design. As a simple example, consider the design of a procedure rand that, whenever it is called, returns an integer chosen at random.
It is not at all clear what is meant by ``chosen at random.'' What we presumably want is for successive calls to rand to produce a sequence of numbers that has statistical properties of uniform distribution. We will not discuss methods for generating suitable sequences here. Rather, let us assume that we have a procedure rand-update that has the property that if we start with a given number x1 and form
x2 = (rand-update x1)
x3 = (rand-update x2)
then the sequence of values x1, x2, x3, ..., will have the desired statistical properties.6
We can implement rand as a procedure with a local state variable x that is initialized to some fixed value random-init. Each call to rand computes rand-update of the current value of x, returns this as the random number, and also stores this as the new value of x.
(define rand
  (let ((x random-init))
    (lambda ()
      (set! x (rand-update x))
      x)))
Of course, we could generate the same sequence of random numbers without using assignment by simply calling rand-update directly. However, this would mean that any part of our program that used random numbers would have to explicitly remember the current value of x to be passed as an argument to rand-update. To realize what an annoyance this would be, consider using random numbers to implement a technique called Monte Carlo simulation.
The Monte Carlo method consists of choosing sample experiments at random from a large set and then making deductions on the basis of the probabilities estimated from tabulating the results of those experiments. For example, we can approximate using the fact that 6/2 is the probability that two integers chosen at random will have no factors in common; that is, that their greatest common divisor will be 1.7 To obtain the approximation to , we perform a large number of experiments. In each experiment we choose two integers at random and perform a test to see if their GCD is 1. The fraction of times that the test is passed gives us our estimate of 6/2, and from this we obtain our approximation to .
The heart of our program is a procedure monte-carlo, which takes as arguments the number of times to try an experiment, together with the experiment, represented as a no-argument procedure that will return either true or false each time it is run. Monte-carlo runs the experiment for the designated number of trials and returns a number telling the fraction of the trials in which the experiment was found to be true.
(define (estimate-pi trials)
  (sqrt (/ 6 (monte-carlo trials cesaro-test))))
(define (cesaro-test)
   (= (gcd (rand) (rand)) 1))
(define (monte-carlo trials experiment)
  (define (iter trials-remaining trials-passed)
    (cond ((= trials-remaining 0)
           (/ trials-passed trials))
          ((experiment)
           (iter (- trials-remaining 1) (+ trials-passed 1)))
          (else
           (iter (- trials-remaining 1) trials-passed))))
  (iter trials 0))
Now let us try the same computation using rand-update directly rather than rand, the way we would be forced to proceed if we did not use assignment to model local state:
  (sqrt (/ 6 (random-gcd-test trials random-init))))
(define (random-gcd-test trials initial-x)
  (define (iter trials-remaining trials-passed x)
    (let ((x1 (rand-update x)))
      (let ((x2 (rand-update x1)))
              ((= (gcd x1 x2) 1)
                     (+ trials-passed 1)
                     x2))
              (else
                     trials-passed
                     x2))))))
  (iter trials 0 initial-x))
While the program is still simple, it betrays some painful breaches of modularity. In our first version of the program, using rand, we can express the Monte Carlo method directly as a general monte-carlo procedure that takes as an argument an arbitrary experiment procedure. In our second version of the program, with no local state for the random-number generator, random-gcd-test must explicitly manipulate the random numbers x1 and x2 and recycle x2 through the iterative loop as the new input to rand-update. This explicit handling of the random numbers intertwines the structure of accumulating test results with the fact that our particular experiment uses two random numbers, whereas other Monte Carlo experiments might use one random number or three. Even the top-level procedure estimate-pi has to be concerned with supplying an initial random number. The fact that the random-number generator's insides are leaking out into other parts of the program makes it difficult for us to isolate the Monte Carlo idea so that it can be applied to other tasks. In the first version of the program, assignment encapsulates the state of the random-number generator within the rand procedure, so that the details of random-number generation remain independent of the rest of the program.
The general phenomenon illustrated by the Monte Carlo example is this: From the point of view of one part of a complex process, the other parts appear to change with time. They have hidden time-varying local state. If we wish to write computer programs whose structure reflects this decomposition, we make computational objects (such as bank accounts and random-number generators) whose behavior changes with time. We model state with local state variables, and we model the changes of state with assignments to those variables.
It is tempting to conclude this discussion by saying that, by introducing assignment and the technique of hiding state in local variables, we are able to structure systems in a more modular fashion than if all state had to be manipulated explicitly, by passing additional parameters. Unfortunately, as we shall see, the story is not so simple.
Exercise 3.5.  Monte Carlo integration is a method of estimating definite integrals by means of Monte Carlo simulation. Consider computing the area of a region of space described by a predicate P(x, y) that is true for points (x, y) in the region and false for points not in the region. For example, the region contained within a circle of radius 3 centered at (5, 7) is described by the predicate that tests whether (x - 5)2 + (y - 7)2< 32. To estimate the area of the region described by such a predicate, begin by choosing a rectangle that contains the region. For example, a rectangle with diagonally opposite corners at (2, 4) and (8, 10) contains the circle above. The desired integral is the area of that portion of the rectangle that lies in the region. We can estimate the integral by picking, at random, points (x,y) that lie in the rectangle, and testing P(x, y) for each point to determine whether the point lies in the region. If we try this with many points, then the fraction of points that fall in the region should give an estimate of the proportion of the rectangle that lies in the region. Hence, multiplying this fraction by the area of the entire rectangle should produce an estimate of the integral.
Implement Monte Carlo integration as a procedure estimate-integral that takes as arguments a predicate P, upper and lower bounds x1, x2, y1, and y2 for the rectangle, and the number of trials to perform in order to produce the estimate. Your procedure should use the same monte-carlo procedure that was used above to estimate . Use your estimate-integral to produce an estimate of by measuring the area of a unit circle.
You will find it useful to have a procedure that returns a number chosen at random from a given range. The following random-in-range procedure implements this in terms of the random procedure used in section 1.2.6, which returns a nonnegative number less than its input.8
(define (random-in-range low high)
  (let ((range (- high low)))
    (+ low (random range))))
Exercise 3.6.  It is useful to be able to reset a random-number generator to produce a sequence starting from a given value. Design a new rand procedure that is called with an argument that is either the symbol generate or the symbol reset and behaves as follows: (rand 'generate) produces a new random number; ((rand 'reset) <new-value>) resets the internal state variable to the designated <new-value>. Thus, by resetting the state, one can generate repeatable sequences. These are very handy to have when testing and debugging programs that use random numbers.
Greg B
  • Tell me a Joke!
« Reply #7 on: November 15, 2019, 08:51:24 AM »
You can tell John's a dad.  He has gotten preachy from a joke.
Granted...I'm guilty as charged as well.
« Reply #8 on: November 15, 2019, 11:59:30 AM »
:) yeah. *sigh*
BIGAL
  • 40 + years of using Autocad
« Reply #9 on: November 16, 2019, 12:41:42 AM »
I bought a raffle ticket multiple numbers, it had multiple prizes, 30+ etc it used a random number generator for the ticket number 1-84,000. No where near that many participants just lots of numbers.
Maybe if I used lee's random gen to pick my numbers I would have had a better chance, oh well beer was cold.
ahsattarian
« Reply #10 on: December 01, 2020, 12:43:04 AM »
use   :     (getvar "cputicks")     or     (getvar "millisecs")    or     combination of both  !!!!
