Author Topic: How do I filter a list?  (Read 2908 times)
dubb
« on: November 12, 2019, 12:44:51 PM »
I am clueless as how to use vl-remove-if vl-member, etc. I would like to know how to filter a list based on an item. For instance. If the list contains "test" I want to remove it from the list and return a list without it.
(setq lst (list '("1" "2" "3" "test") '("a" "b" "c" "finished") '("a" "b" "c" "test")))
desired result to filter out "test"
_$ lst
(("a" "b" "c" "finished"))
desired result to filter out "finished"
_$ lst
(("1" "2" "3" "test")("a" "b" "c" "test"))
Re: How do I filter a list?
« Reply #1 on: November 12, 2019, 01:18:32 PM »
If case is not a concern perhaps ...
(defun foo ( item-to-remove lst )
    (if (atom (car lst))
        (vl-remove item-to-remove lst)
        (mapcar (function (lambda (x) (foo item-to-remove x))) lst)
(foo "test"
   '(   ("1" "2" "3" "test")
    ("1" "2" "3")
    ("a" "b" "c")
Cheers.
« Last Edit: November 12, 2019, 01:22:30 PM by MP »
dubb
« Reply #2 on: November 12, 2019, 01:29:34 PM »
Like the the function but it only removes the string for me. I want to remove an entire list from the list.
Desired list if "finished" was filtered.
(foo "test"
    ("1" "2" "3")
    ("a" "b" "c")
Cheers.
« Reply #3 on: November 12, 2019, 01:34:27 PM »
Wow,  I misunderstood.
(vl-remove-if
   '(lambda (x) (member "test" x))
(vl-remove-if
   '(lambda (x) (member "finished" x))
>> (("1" "2" "3" "test") ("a" "b" "c" "test"))
dubb
« Reply #4 on: November 12, 2019, 01:39:42 PM »
You're a genius!
It works!
Here is my failed attempt.
(mapcar '(lambda (x)
(if (/= (vl-position "test" (nth x lst)) nil)
     (vl-remove (nth x lst) lst)
)lst)
Thanks!
(vl-remove-if
(vl-remove-if
« Reply #5 on: November 12, 2019, 02:05:11 PM »
Once you get comfortable with the docs you’ll realize I’m not. Sorry for the scenic route, I frequently read WAY too fast and think I’ve the gist ...
Cheers.
« Reply #6 on: November 12, 2019, 05:25:04 PM »
Whilst by far the easiest method would be to make use of the vl-remove-if function, e.g.:
  1. (defun foo1 ( itm lst )
  2.     (vl-remove-if '(lambda ( x ) (member itm x)) lst)
  3. )
There are several other ways to tackle this particular task - for example, using basic iteration:
  1. (defun foo2 ( itm lst / rtn )
  2.     (foreach x lst (or (member itm x) (setq rtn (cons x rtn))))
  3.     (reverse rtn)
  4. )
Or recursion:
  1. (defun foo3 ( itm lst )
  2.     (if lst
  3.         (if (member itm (car lst))
  4.             (foo3 itm (cdr lst))
  5.             (cons (car lst) (foo3 itm (cdr lst)))
  6.         )
  7.     )
  8. )
dubb
« Reply #7 on: November 12, 2019, 06:00:15 PM »
Awesome! Thank you guys very much. I can understand vl-remove a little better now.
Greg B
  • Tell me a Joke!
« Reply #8 on: November 13, 2019, 08:52:31 AM »
I was thinking the answer was "alphabetically".
