Author Topic: How to Highlight list Pline is Square in the drawing?  (Read 2363 times)
Sieu khung khiep
  • Mosquito
« on: November 12, 2019, 04:26:06 AM »
Hi, I have searched for answers in many forums but have not found the answer yet.
This is the code I wrote, however my list pline have not been highlighted as expected
Code - vb.net: [Select]
  1. Dim lstRec As New List (Of Polyline)
  2. Dim Prsel As PromptSelectionResult = ed.GetSelection (New PromptSelectionOptions () With {
  3.           .MessageForAdding = "Select Pline:"})
  4.
  5.   With cadTrans
  6.                  For Each ID As ObjectId In Prsel.Value.GetObjectIds
  7.                      Dim pli As Polyline = DirectCast (.GetObject (ID, OpenMode.ForRead), Polyline)
  8.                      If isSquare (pli) Then
  9.                          lstRec.Add (pli)
  10.                      End If
  11.                  next
  12. ...
  13. End with
  14.   ed.SetImpliedSelection (lstRec. [Select] (Function (ent) ent.ObjectId) .ToArray ()) 'from gile
  15. ed.regen
  16. ed.UpdateScreen ()
  17. 'Continue code...
  18.
I want only the pline is Square to be highlighted
Can you give me more instructions?
Thank for all.
« Last Edit: November 12, 2019, 04:51:39 AM by Sieu khung khiep »
Atook
  • AKA Tim
Re: How to Highlight list Pline is Square in the drawing?
« Reply #1 on: November 12, 2019, 12:05:36 PM »
I can't see anything offhand, you might try Autodesk.AutoCAD.Internal.Utils.SelectObjects() instead of SetImpliedSelection()
Unless you need properties of the rectangles somewhere else, I'd recommend storing the lstRec as a list of ObjectIDs. I've found that storing and passing ObjectIDs is superior to storing and passing Entities.
I don't write VB.NET, but it might look something like this:
  1. Dim lstRec As New List (Of ObjectId)' <-store ObjectID instead of rectangle
  4.
  5.   With cadTrans
  9.             lstRec.Add (ID)
  10.         End If
  11.     next
  12. ...
  13. End with
  14.   ed.SetImpliedSelection (lstRec.ToArray()) 'from gile
  15. ed.regen
« Last Edit: November 12, 2019, 12:10:21 PM by Atook »
gile
  • Marseille, France
« Reply #2 on: November 12, 2019, 12:45:57 PM »
This should work:
Code - C#: [Select]
  1.             var options = new PromptSelectionOptions(){ MessageForAdding = "\nSelect Polylines" };
  2.             var filter = new SelectionFilter(new[] { new TypedValue(0, "LWPOLYLINE") });
  3.             var selection = ed.GetSelection(options, filter);
  4.             if (selection.Status == PromptStatus.OK)
  5.             {
  6.                 ObjectId[] ids;
  7.                 using (var tr = new OpenCloseTransaction())
  8.                 {
  9.                     ids = selection.Value.GetObjectIds()
  10.                         .Select(id => (Polyline)tr.GetObject(id, OpenMode.ForRead))
  11.                         .Where(pl => IsSquare(pl))
  12.                         .Select(pl => pl.ObjectId)
  13.                         .ToArray();
  14.                     tr.Commit();
  15.                 }
  16.                 ed.SetImpliedSelection(ids);
  17.             }
Sieu khung khiep
  • Mosquito
« Reply #3 on: November 13, 2019, 04:22:20 AM »
Hi Atook, It actually worked, the code ran a lot faster than before. Thank you for letting me know .
Sieu khung khiep
  • Mosquito
« Reply #4 on: November 13, 2019, 04:27:13 AM »
                {    ids = selection.Value.GetObjectIds()
                        .ToArray();
                    tr.Commit();
Hi Gile,  :yay!:
Very concise and easy to understand, I learned a little more to code better from you. It worked for me. thank you very much.
