Author Topic: double apostrophe  (Read 5884 times)
ElpanovEvgeniy
  • Moscow (Russia)
double apostrophe
« on: November 11, 2019, 10:45:47 AM »
Hello!
How does this code work?
  1. (setq l '((1 2 3)(4 5)(6 7 8 9)))
  2. ;;>> (list (+ 1 2 3) (+ 4 5) (+ 6 7 8 9))
  3.
  4.
  5. (mapcar ''((x) (apply '+ x)) l)
My student wrote it, but I don’t understand this syntax...
Grrr1337
Re: double apostrophe
« Reply #1 on: November 11, 2019, 12:19:27 PM »
Hello,
Here are some self-explanations of mine
Then Lee made it clear with his comment
For short he's mapcaring with unnamed/anonymous defun-q.
(apply ''((a b c)(a b c))
vevo.bg
VovKa
  • Ukraine
« Reply #2 on: November 11, 2019, 12:28:44 PM »
let's hope this student is not reading this thread ;)
« Reply #3 on: November 11, 2019, 01:06:27 PM »
(setq foo '((x) (* x x)))
Assigns the structure of a function to symbol foo, albeit not optimized.
(foo 2) >> 4
(mapcar '((x) (* x x)) '(2 4 6)) >> *crash*
Doesn't work because '((x) (* x x)) when evaluated returns the structure of a function - not a quoted function. Mapcar wants a quoted function.
(mapcar 'foo '(2 4 6)) >> (4 16 36)
Is functionally the same as:
(mapcar ''((x) (* x x)) '(2 4 6)) >> (4 16 36)
Works because ''((x) (* x x)) when evaluated returns the structure of a quoted function.
Hope that was clear/helps; cheers.
« Reply #4 on: November 11, 2019, 01:32:05 PM »
The list structure itself is essentially the same as doing this:
  1. (mapcar (defun-q f ( x ) (apply '+ x)) l)
Since:
  1. _$ (defun-q f ( x ) (apply '+ x))
  2. F
  3. _$ f
  4. ((X) (APPLY (QUOTE +) X))
Here defun-q returns the function symbol - i.e. an unevaluated/quoted function.
The function could alternatively be defined by quoting the literal list:
  2. F
  3. _$ (setq g '((X) (APPLY (QUOTE +) X)))
  5. _$ (equal f g)
  6. T
Then, it follows that this:
  1. _$ (setq l '((1 2 3) (4 5) (6 7 8 9)))
  2. ((1 2 3) (4 5) (6 7 8 9))
  3. _$ (mapcar 'g l)
  4. (6 9 30)
Can become:
  1. _$ (mapcar ''((X) (APPLY (QUOTE +) X)) l)
  2. (6 9 30)
« Last Edit: November 11, 2019, 01:38:00 PM by Lee Mac »
roy_043
  • BricsCAD 18
« Reply #5 on: November 11, 2019, 05:30:27 PM »
I always think of this structure as a form 'complification'. But some programmers seem to love it.
BTW BricsCAD does not accept it.
hanhphuc
« Reply #6 on: November 11, 2019, 08:10:19 PM »
hi Roy just for fun
i try put triple quotes (in line 10) still can work in ACAD
' ' ' ((x) (setq s (+ x s)) s)
triple  ' ' '  ok but double  ' '  yields error
Bridscad try using ' ' double quotes possible?
' ' ((x) (setq s (+ x s) s)
  1. (mapcar '(lambda (x)
  2.            (last
  3.             (eval
  4.              (cons
  5.               'cond
  6.               (mapcar
  7.                '(lambda (i)
  8.                   (cons
  9.                    (equal (nth (vl-position x l) l) i)
  10.                    (mapcar 'cons '(setq mapcar) (list '(s 0.0) (list ' ' ' ((x) (setq s (+ x s)) s) i)))
  11.                    )
  12.                   )
  13.                l
  14.                )
  15.               )
  16.              )
  17.             )
  18.            )
  19.         (setq l '((list 1 2 3) (list 4 5) (list 6 7 8 9)))
  20.         )
  21.
( apply 'equal "hp" "happy" "hạnh phúc" "ハッピー" "幸福" "행복" ) ; error: too many arguments
Grrr1337
« Reply #7 on: November 12, 2019, 06:39:07 AM »
  2.            (last
  3.             (eval
  4.              (cons
  5.               'cond
  6.               (mapcar
  7.                '(lambda (i)
  8.                   (cons
  11.                    )
  12.                   )
  13.                l
  14.                )
  15.               )
  16.              )
  17.             )
  18.            )
  20.         )
  21.
Thats quite perplexing syntax, hanhphuc  :idiot2:  :-D
vevo.bg
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #8 on: November 12, 2019, 08:36:45 AM »
Hello!
Thank you all so much!
I did not know about such use of defun-q
« Reply #9 on: November 12, 2019, 09:22:43 AM »
I don’t "love it" but the native form (i.e. raw list via setq or defun-q) of function defs is propagate-able, whereas optimized function defs (via defun) are not. I touch on it briefly here. Cheers.
« Reply #10 on: November 12, 2019, 09:26:39 AM »
Hello!
Pleased if I helped illuminate in some small way and reciprocate for the buckets of grey matter flexion you’ve shared during your swamp tenure. :)
roy_043
  • BricsCAD 18
« Reply #11 on: November 12, 2019, 04:08:01 PM »
If you use the double apostrophe syntax there is no symbol to propagate.
« Reply #12 on: November 12, 2019, 08:00:30 PM »
I was talking about propagating defuns.
roy_043
  • BricsCAD 18
« Reply #13 on: November 13, 2019, 02:48:18 AM »
I know. But the aficionados of the syntax (double apostrophe) being discussed here are not concerned with that. They are not creating a named variable (symbol).
