Author Topic: Can a PICKSET be treated as a list for use with mapcar?  (Read 2811 times)
Colby
« on: November 08, 2019, 12:01:19 PM »
I wanted to do something like the following:
(defun SelectionSet->VLA-Object (ssEnt / obj)
   (if (/= ssEnt nil)
      (setq obj (vlax-ename->vla-object (ssname ssEnt 0)))
      nil
(defun C:SSS ()
   (setq ssents (ssget))
   (setq temp (mapcar 'SelectionSet->vla-object ssents))
If I review ssents in VLIDE, it appears very list-esq, but does not seem to function like one.  Is something like this possible?
[edit] I know I can loop through it with repeat, but I'd like to minimize the amount of typing I need to do in the future.
« Last Edit: November 08, 2019, 12:22:14 PM by Colby »
Re: Can a PICKSET be treated as a list?
« Reply #1 on: November 08, 2019, 12:23:08 PM »
Read this: http://www.lee-mac.com/selectionsettolist.html
You have to convert the selset to a list .. many examples there.
Welcome to TheSwamp. :)
Here is an example using mapcar albeit slower than many other methods:
  1. (defun selectionset->vla-object_>list (s)
  2.   (if s
  3.     (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))))
  4.   )
  5. )
« Last Edit: November 08, 2019, 12:26:25 PM by ronjonp »
Colby
« Reply #2 on: November 08, 2019, 12:33:20 PM »
  2.   (if s
  4.   )
  5. )
Thanks ronjonp!
It looks like using mapcar on the function selectionset->vla-object and passing each selection set item just isn't possible.
Thank you for your help.
Re: Can a PICKSET be treated as a list for use with mapcar?
« Reply #3 on: November 08, 2019, 01:55:11 PM »
In short: mapcar operates on lists; a selection set isn't a list.
If you specifically wish to use mapcar, you will need to first construct a list of entities from a given selection set either by iterating over the set or using ssnamex; however, rather than iterating over the selection set to construct a list, and then iterating over the list (using mapcar or other list iterators) to operate on each entity, you might as well operate on the entities whilst iterating over the set - I describe various methods to accomplish this in my tutorial on Selection Set Processing.
Marc'Antonio Alessi
  • Marco
« Reply #4 on: November 09, 2019, 03:57:17 AM »
Another version:
(defun ALE_SelSet_ToObjList (SelSet / Countr ObjLst)
  (if SelSet
    (repeat (setq Countr (sslength SelSet))
      (setq ObjLst (cons (vlax-ename->vla-object (ssname SelSet (setq Countr (1- Countr)))) ObjLst))
