Author Topic: entmod not working  (Read 3046 times)
jlogan02
entmod not working
« on: November 08, 2019, 11:25:07 AM »
My entmod doesn't seem to be working here.
Layer gets created with the -N suffix and color red but the selected object doesn't get moved to that new layer.
  1. (defun c:ByToRed ( / e i l n s x )
  2.  (defun *error* (msg)
  3.     (if osm
  4.       (setvar 'osmode osm)
  5.     )
  6.     (if (not (member msg '("Function cancelled" "quit / exit abort")))
  7.       (princ (strcat "\nError: " msg))
  8.     )
  9.     (princ)
  10.   )
  11.   (if (setq s (ssget ":L"))
  12.       (repeat (setq i (sslength s))
  13.            (setq x (entget (ssname s (setq i (1- i))))
  14.                  l (assoc 8 x)
  15.                  n (strcat (cdr l) "-N")
  16.            )
  17.            (if (not (tblsearch "layer" n))
  18.                (progn
  19.                    (setq e (entget (tblobjname "layer" (cdr l))))
  20.                    (entmake (subst (cons 2 n) (assoc 2 e) (subst '(62 . 1) (assoc 62 e) e)))
  21.
  22.                           )
  23.            )
  24.            (entmod (subst (cons 8 n) 1 x))
  25.             )
  26.    )
  27.     (prompt "\nAll objects have been moved to new construction layer")
  28.  (princ)
  29. )
Something simple I'm sure. Well, not to me anyway.
J. Logan
J. Logan
ACAD 2018
I am one with the Force and the Force is with me.
AutoCAD Map 2018 Windows 10
Re: entmod not working
« Reply #1 on: November 08, 2019, 12:01:26 PM »
  3.     (if osm
  5.     )
  8.     )
  9.     (princ)
  10.   )
  14.                  l (assoc 8 x)
  16.            )
  18.                (progn
  21.
  22.                           )
  23.            )
  25.             )
  26.    )
  28.  (princ)
  29. )
J. Logan
Try this:
  1.       ;; This
  2.       (entmod (append x (list (cons 8 n))))
  3.       ;; Or this
  4.       (entmod (subst (cons 8 n) (assoc 8 x) x))
  5.       ;; (entmod (subst (cons 8 n) 1 x))
The red layer creation could be simplified to this too:
  1. (entmake (append e (list (cons 2 n) '(62 . 1))))
« Last Edit: November 08, 2019, 12:05:04 PM by ronjonp »
tombu
  • ByLayer=>Not0
« Reply #2 on: November 08, 2019, 12:07:43 PM »
Change
(entmod (subst (cons 8 n) 1 x))to
(entmod (setq x (subst (cons 8 n) 1 x)))
Tom Beauford P.S.M.
jlogan02
« Reply #3 on: November 08, 2019, 12:12:38 PM »
Thanks Ron,
      ;; Or this
  1. (entmod (subst (cons 8 n) (assoc 8 x) x))
What does the last ... x)) do here???
J. Logan
ACAD 2018
« Reply #4 on: November 08, 2019, 12:19:12 PM »
Thanks Ron,
      ;; Or this
See if you can figure it out :)
  1.            (setq x (entget (ssname s (setq i (1- i))))
  2.                  l (assoc 8 x)
  3.                  n (strcat (cdr l) "-N")
  4.            )
jlogan02
« Reply #5 on: November 08, 2019, 12:42:44 PM »
  2.                  l (assoc 8 x)
  4.            )
it references the items found by the user selection.
J. Logan
ACAD 2018
dgorsman
« Reply #6 on: November 08, 2019, 03:24:33 PM »
I usually put heavily nested statements on separate lines, so it's easier to follow the arguments.  Check the arguments required for the (subst ...) function, and what order they're in.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
BIGAL
  • 40 + years of using Autocad
« Reply #7 on: November 08, 2019, 08:27:54 PM »
This is were vl is so much easier (vla-put-layer obj newlayer) and to understand.
