Author Topic: How to simplify a lwpolyline with 5000+ vertices in it?  (Read 5098 times)
Vikram
« on: November 06, 2019, 01:24:55 AM »
Hi!
I have a lwpolyline with 5000+ vertices in it. I actually used pedit.lisp made by Kent Cooper but it is not supporting for the lwpolyline with so many vertices.My intellicad crashes when I use it. But it works fine with 2000+ vertices.
Basically I want to obtain smooth curve out of numerious small lines. So I convert this small lines in polyline by using pedit and then I spline it.I couldn't use pldiet.lisp on spline so I have to again explode that spline and convert it into polyline again.When I explode it it I get 5000 vertices. Intially I have 700 points but after exloding I get so many points.
So these following things can help me
1) If I could simplify the polyline after I spline it. For Eg: Pedit->Join->Spline->Simplify
   (pldiet wont support spline that's why I have to go Pedit->Join->Spline->Explode->Pedit->Join->Simplify )
2)If I could explode the polyline in minimum vertices with help of some routine.
I have attached the drawing for reference test2.dxf
« Last Edit: November 06, 2019, 01:54:01 AM by Vikram »
kpblc
Re: How to simplify a lwpolyline with 5000+ vertices in it?
« Reply #1 on: November 06, 2019, 01:34:37 AM »
How did you get dxf file with repeated entity handles? AutoCAD 2018 can't open this dxf, and I have no time to edit it manually. Attach dwg file.
P.S. Without opening file: try to ise _.pedit command at first part of your lines, then repeat this command to another part, and repeat it until you get good enough result.
Sorry for my English.
Vikram
« Reply #2 on: November 06, 2019, 01:55:35 AM »
Thanks for your reply Sir.Now I also have attached dwg file. I will try your method
kpblc
« Reply #3 on: November 06, 2019, 05:18:29 AM »
I think you have to erase duplicated vertexes and segments. Use _.overkill command.
Secondary try to use pl-tools: https://forum.dwg.ru/showthread.php?t=8284 . Maybe it could help you.
Vikram
« Reply #4 on: November 06, 2019, 08:50:59 AM »
Those tools gave me a high hope! they looks useful. But unfortunately it didn't work for me.It threw error bad argument.
PS: I'm using IntelliCad
ScottMC
« Reply #5 on: November 06, 2019, 10:10:09 PM »
Mr Sanders did quite a job on that Rolling_Ball tool for sure. I'm gonna spend some time learning from that.
Vikram
« Reply #6 on: November 06, 2019, 10:22:55 PM »
For what purpose Rolling ball tool was used? Do you have the lisp file of its?
« Last Edit: November 06, 2019, 11:22:20 PM by Vikram »
hak_vz
  • Mosquito
« Reply #7 on: November 09, 2019, 06:48:05 AM »
ahsattarian
« Reply #8 on: December 01, 2020, 07:25:21 AM »
See if this Result is what u need  :
Then I will offer u its code  !!!!
