What are your rules & procedure for creating this cloud?
Example:Locations - model space only
User input - pick corners for rectangle or pick points to create a ployline outline.
Geometry - Arc min & max size or fixed size Lines fixed length Spacing between geometry, fixedLayer - current or predefined layer
Do you understand that all this information must be defined before you can create a LISP routine?
