Author Topic: Custom Cloud  (Read 3629 times)
mfadzli87
  • Mosquito
Custom Cloud
« on: November 05, 2019, 08:21:34 PM »
Hi friends,
My office is using custom cloud for drawings. Right now i create it manually. If possible anyone here can create lisp for me. Here is the sample the cloud.  :smitten:
« Last Edit: November 05, 2019, 08:25:09 PM by mfadzli87 »
Re: Custom Cloud
« Reply #1 on: November 06, 2019, 09:04:19 AM »
What are your rules & procedure for creating this cloud?
Example:Locations - model space only
User input - pick corners for rectangle or pick points to create a ployline outline.
Geometry - Arc min & max size or fixed size                 Lines fixed length                 Spacing between geometry, fixedLayer - current or predefined layer
Do you understand that all this information must be defined before you can create a LISP routine?
Re: Custom Cloud
« Reply #3 on: November 06, 2019, 09:33:08 AM »
Why would you take the time to draft this?  :-o Look into making a linetype and use revcloud if this really holds a value for your company.
Re: Custom Cloud
« Reply #4 on: November 06, 2019, 10:22:32 AM »
... My office is using custom cloud for drawings ...
What's the benefit for the effort / cost?
mfadzli87
  • Mosquito
Re: Custom Cloud
« Reply #5 on: November 06, 2019, 08:33:54 PM »
Hi sir, The rules is same as autocad revcloud. If possible to draw rectangle/polyline and convert it to arc with geometry. The size/spacing maybe can refer the DIMSCALE for different scale of drawing.   :-)
« Last Edit: November 06, 2019, 08:40:14 PM by mfadzli87 »
mfadzli87
  • Mosquito
Re: Custom Cloud
« Reply #6 on: November 06, 2019, 08:36:47 PM »
This if for my own benefit only to speed up my drafting skills.. :lol:
mfadzli87
  • Mosquito
Re: Custom Cloud
« Reply #7 on: November 06, 2019, 08:37:47 PM »
Thanks sir, it is a good idea also.. :-)
