Author Topic: Extend corridor to an angle  (Read 939 times)
PHX cadie
« on: November 04, 2019, 09:46:22 PM »
Been gone awhile and this is first for me to post to this board. Yea!
I have a surface (created from a corridor, triangles shown) and I need to run it to intercept an existing, curved EOP and I have no idea how to even cheat it, (other than putting Acad lines on the profile).
Create feature line to complete the left side?
Run the corridor to the furthest top point, create surface from corridor, then use an outer boundary to trim the surface?
Sorry Im having a mental block..........assembly/perpendicular to alignment.....brain freeze...
Any ideas for a novice using 2018 C3D?
Acad 2013 and XM
