Pan a Distance Within a ViewportDouble click the viewport to activate it.-P <enter> to start the pan command in the command line.Pick a point inside of the viewport to specify the base point.Move the cursor in the desired direction of the pan (use ortho)Enter the specific distance and hit <enter>
Not sure if this is what you are doing but..Code: [Select]Pan a Distance Within a ViewportDouble click the viewport to activate it.-P <enter> to start the pan command in the command line.Pick a point inside of the viewport to specify the base point.Move the cursor in the desired direction of the pan (use ortho)Enter the specific distance and hit <enter>
