Author Topic: Move VP area in model  (Read 3262 times)
HasanCAD
« on: October 23, 2019, 11:55:46 AM »
Hi All,
I am attaching PDFs to DWG and want to view each one in a separate layout as attached.
Distance in Model between each PDF is 1
Offset in VP is 370
I am wondering is there a way to move the viewport fir that distance ?
DanB
Re: Move VP area in model
« Reply #1 on: November 14, 2019, 04:49:42 PM »
Not sure if this is what you are doing but..
Pan a Distance Within a Viewport
Double click the viewport to activate it.
-P <enter> to start the pan command in the command line.
Pick a point inside of the viewport to specify the base point.
Move the cursor in the desired direction of the pan (use ortho)
Enter the specific distance and hit <enter>
HasanCAD
« Reply #2 on: November 20, 2019, 06:51:47 AM »
Thanks DanB
I was asking for an idea to move VPort viewing area to another place
any way I made it.
Thnaks
