Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
lisp script for draw object (panels)
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: lisp script for draw object (panels) (Read 2070 times)
suraj.jangam22
Guest
on:
October 22, 2019, 02:54:28 AM »
I have attached herewith drafting flow for the drawing, i want script for the same process. please guide me please. i am new here & i have not much knowledge about LISP program.
ALSO PLEASE SEE BELOW I HAVE ATTACHED SCRIPT WHICH I HAVE WRITE FOR START.
Code - Auto/Visual Lisp:
[Select]
defun
c:panel
len wid pt1 pt2 pt3 pt4
setq
pt1
getpoint
\n
Pick lower left Corner"
setq
Len
Getreal
\n
Enter length"
setq
wid
Getreal
\n
Width"
setq
pt2
polar
Pt1
0.0
len
setq
pt3
polar
pt2
pi
2.0
wid
setq
pt4
polar
pt3 pi len
command
"pline"
pt1 pt2 pt3 pt4
"c"
C:panel
EDIT (John): added code tags.
Last Edit: October 23, 2019, 09:19:13 AM by John Kaul (Se7en)
Logged
suraj.jangam22
Guest
Re: lisp script for draw object (panels)
Reply #1 on:
October 22, 2019, 07:47:51 AM »
see what i have started ............
[Select]
defun
c:panel
setq
pt1
getpoint
\n
setq
Len
Getreal
\n
Enter length"
setq
wid
Getreal
\n
Width"
setq
pt2
polar
Pt1
0.0
len
setq
pt3
polar
pt2
pi
2.0
wid
setq
pt4
polar
pt3 pi len
command
"pline"
pt1 pt2 pt3 pt4
"c"
if
lay
setvar
'CLAYER lay
princ
; layers
command
"_.LAYER"
"_T"
"White"
"_M"
"White"
"_Color"
7
"White"
; layers
C:panel
EDIT (John): Added code tag.
Last Edit: October 23, 2019, 09:18:29 AM by John Kaul (Se7en)
Logged
Global Moderator
Seagull
Reply #2 on:
October 22, 2019, 11:46:20 AM »
When you use command you must manage the SNAPs
Logged
Global Moderator
Seagull
Reply #3 on:
October 25, 2019, 09:16:51 AM »
Attached is a very old routine that uses Command. You can learn from that.
Logged
BIGAL
Swamp Rat
40 + years of using Autocad
Reply #4 on:
October 25, 2019, 07:51:36 PM »
Also posted here suggestions made.
https://www.cadtutor.net/forum/topic/68932-draw-panels-using-vba-or-excel/?tab=comments#comment-556745
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
