Just copy this line to command line
(if (not AH:Toggs)(load "Multiple toggles.lsp"))
Then copy this line to command line and look at result (0 1 0 1 0) etc it should match what you tick on.off
(setq ans (ah:toggs '("Tick off/on " "Blocks" "Dimension" "Hatch" "Images" "Viewports")))
Paste it again a few times and look at the ( 1 1 1 1 1) etc make sure it matches on is a 1, off is a 0
Let me know if its not changing.
