Author Topic: Lisp to e-mail content to helpdesk.  (Read 11223 times)
Re: Lisp to e-mail content to helpdesk.
« Reply #15 on: October 15, 2019, 09:39:38 AM »
If you know the name of your smtp server etc ...
  1. ...
  2.         (setq
  3.             server-name "mail.your-legit-server.com"
  4.             server-port 25
  5.             using-port  2
  6.             cdo         (vlax-create-object "CDO.Message")
  7.             server      (vlax-get-property (vlax-get-property cdo 'configuration) 'fields)
  8.         )
  9. ...
Question: does port 25 still work (I mean, I thought port 25 was blocked now-a-days)? Good if it does, I guess.
Lonnie
« Reply #16 on: October 15, 2019, 12:52:23 PM »
I will try your suggestion when I have time. That won't be today.
As a hmmm thing not a look at and interpret thing.
This is what you get when you look at the html string that gets sent with the original suggestion.
Note it's not what mine looks like when I send it. It's how outlook is interpreting it on the received side.
« Reply #17 on: October 15, 2019, 01:03:05 PM »
I've been successfully using the code I posted for years - it's still in place, functioning. That said, it really depends upon your mail server - recommend one talks to their IT folks for the sendusing, smtpserver & smtpserverport configuration values (lines 52-54 in the code I posted).
Good gawd, yet another reason NOT to use outlook. That is horrendous, polluted <expletive deleted>.
« Reply #18 on: October 15, 2019, 01:17:41 PM »
Good gawd, yet another reason NOT to use outlook. That is horrendous, polluted sh@t.
Oh, I'm not questioning the code (I'm sure it works) but I was just questioning port 25. I know a lot of ISPs here, in the states, block 25 for client to server communications ('cutting down on spam" and all of that stuff). In the US, and/if I understand the scenario properly--doubtful--25 is only used now-a-days in between servers; client side communications are supposed to use TSL (587). If 25 works, great.
Yeah, that's outlook/html email for you; messy stuff. :) You can change your settings to Plain text and get cleaner results.
« Reply #19 on: October 15, 2019, 01:42:41 PM »
That’s how I read it.
Or just eschew that route entirely.
Lonnie
« Reply #20 on: October 15, 2019, 01:45:36 PM »
I am just a small cog in a big company. I don't get to choose how people send or receive mail. It's outlook and they get to choose html or plain text.  :2funny:
« Reply #21 on: October 15, 2019, 01:48:04 PM »
How users read mail is out of your hands. How you send it is in your hands.
Lonnie
« Reply #22 on: October 15, 2019, 01:58:17 PM »
True for how I send it.
As you've hooked me into playing. Here is what it came back with
Command: (_get-my-full-name)
"C:\\Users\\lshaw\\Documents\\Drawing1.dwg"
Mail did not work too well but that could have been my mistake. (Ok it was my mistake.) I will see what comes out.
« Reply #23 on: October 15, 2019, 02:00:56 PM »
That's for a dwg that hasn't been saved. What about a drawing that resides within the unc path you indicated earlier?
Lonnie
« Reply #24 on: October 15, 2019, 02:06:10 PM »
 :uglystupid2: You're so picky. GD&R (Grin Duck and Run.)
"\"\\\\dce\\boi\\Projects\\2018 Jobs\\18PAC01 - Garden Brook Senior Village - Garden Grove, CA\\Cadd\\Apartments\\18PAC01-M215.dwg\""
« Reply #25 on: October 15, 2019, 02:17:41 PM »
You're so picky.
:uglystupid2: You're so vague.
- Carly Simon.
Should work.
What does (findfile (_get-my-full-name)) return?
What does (findfile (apply 'strcat (mapcar 'getvar '(dwgprefix dwgname)))) return?
Lonnie
« Reply #26 on: October 15, 2019, 02:21:58 PM »
Command: (findfile (_get-my-full-name))
"\\\\dce\\Projects\\2019\\19DUP01 - Dupont GWP Upgrade\\Cadd\\19DUP01_mpx-model.dwg"
Command: (findfile (apply 'strcat (mapcar 'getvar '(dwgprefix dwgname))))
« Reply #27 on: October 15, 2019, 02:49:15 PM »
That result suggests the following should work provided you know the appropriate smtp values to code into the _send-email function:
(_send-email                      ;; see pickey email thread: http://bit.ly/2BfbU2g
    (_get-users-email-addy)       ;; do-able via active directory
    (_get-help-desk-email-addy)   ;; a constant you would provide
    (_get-email-subject)          ;; either hard coded or via some input method
    (_get-email-body)             ;; either hard coded or via some input method
    (_get-my-full-name)           ;; see pickey email thread: http://bit.ly/2BfbU2g
« Last Edit: October 15, 2019, 03:02:49 PM by MP »
« Reply #28 on: October 17, 2019, 09:22:40 AM »
Regarding _get-users-email-addy the following should work (I say should because I just translated it from vb and I'm not on an active directory network at home so I can't test it). Would be great if someone could verify if it works or not, thanks.
(defun _get-users-email-addy ( / network user domain conn qry ldaprs fld result )
    (vl-catch-all-apply
       '(lambda ( )
            (setq
                network (vlax-create-object "Wscript.Network")
                user    (vlax-get network 'username)
                domain  (vlax-get network 'userdomain)
                conn    (vlax-create-object "ADODB.Connection")
            (vlax-put conn 'provider "ADsDSOObject")
            (vlax-invoke conn 'open "ADSI")
            (setq
                qry    (strcat "select mail from 'LDAP://" domain "' ")
                qry    (strcat qry "WHERE objectClass = 'user' and ")
                qry    (strcat qry "samAccountName = '" user "'")
                ldaprs (vlax-invoke conn 'execute qry)
                fld    (vlax-invoke (vlax-get ldaprs 'fields) 'item "mail")
                result (vlax-get fld 'value)
    (vl-catch-all-apply 'vlax-release-object (list fld))
    (vl-catch-all-apply 'vlax-release-object (list ldaprs))
    (vl-catch-all-apply 'vlax-release-object (list conn))
    (vl-catch-all-apply 'vlax-release-object (list network))
    (if (eq 'str (type result)) result)
(_get-users-email-addy) >> yourname@yourdomain.com
Cheers.
Lonnie
« Reply #29 on: October 17, 2019, 01:19:20 PM »
I think I'm good for now.
lisp is in committee and we'll see what type of camel (Ol' saw. A camel is a horse designed by committee.) comes out. I've already had to cut it down and change words (Sigh).
Once again You've all been great. I hope I can contribute later on and answer someone's question. I've been doing it for a few years (I started before oops was a lisp routine.)  and know a few tricks.
