Author Topic: Change all 3D solid faces+edges color  (Read 1630 times)
w64bit
« on: October 08, 2019, 12:25:28 PM »
How can I change the color of all faces 3D solids in a drawing? To ByLayer.
With SOLIDEDIT I have to select manually.
Ctrl + A does not solve this.
Thank you
« Last Edit: October 16, 2019, 08:07:12 AM by w64bit »
ribarm
  • Marko Ribar, architect
Re: Change all 3D solid faces+edges color
« Reply #1 on: October 24, 2019, 10:18:30 AM »
I just looked into SOLIDEDIT - Face - Color options and after you pick single face, you can type ALL to select them all - BYLAYER is then default choice when color dialog pops up...
What version of ACAD do you have - maybe this isn't functioning with your case... I tested this on A2018...
BTW. What happens when you just select 3DSOLID and switch it's color to new one and then restore it back? I suppose CAD should change all faces to object color you've chosen...
M.R. on Youtube
