Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
.NET
Topic:
Edit attributes on closed drawing
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Edit attributes on closed drawing (Read 2184 times)
latour_g
Newt
on:
October 03, 2019, 09:37:27 AM »
This might be a little tricky .. or not but I can't figure out the solution
I have a command that edit attributes on closed drawing. It only change the content. It works fine for changing the content but it does not adjust at the right justification. It keep the actual insertion point so it is offset.
Any idea ?
Thank you !
Code - C++:
[Select]
BlockTableRecord bDef
BlockTableRecord
tr.
GetObject
blkTable
cNomBlk
, OpenMode.
ForWrite
false
ObjectIdCollection objColl
bDef.
GetBlockReferenceIds
false
true
foreach
ObjectId objId in objColl
BlockReference br
BlockReference
tr.
GetObject
objId, OpenMode.
ForWrite
true
if
br.
AttributeCollection
Count
0
foreach
ObjectId id in br.
AttributeCollection
AttributeReference att
AttributeReference
tr.
GetObject
id, OpenMode.
ForWrite
if
attValLst.
Contains
att.
Tag
ToUpper
att.
TextString
attValueLst
att.
Tag
ToUpper
ToString
br.
RecordGraphicsModified
true
Last Edit: October 03, 2019, 11:19:02 AM by latour_g
Logged
n.yuan
Bull Frog
Re: Edit attrbiutes on closed drawing
Reply #1 on:
October 03, 2019, 09:57:38 AM »
I assume "closed drawing" means opened side database, in which you update attributes of certain blockreferences.
This is a know issue and have been discussed in AutoCAD discussion forum, and maybe also in this forum, a few times; such as this:
https://forums.autodesk.com/t5/net/changed-attribute-text-in-sidedb-does-not-re-align-when/m-p/8665044
HTH
Logged
latour_g
Newt
Re: Edit attributes on closed drawing
Reply #2 on:
October 03, 2019, 11:21:03 AM »
You are absolutely right, I needed to use HostApplicationServices.WorkingDatabase
Thank you so much !
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
.NET
Topic:
