Author Topic: Call Out Bubble Dynamic Block  (Read 1169 times)
Pukenzz
« on: September 24, 2019, 03:58:27 PM »
Im looking for a dynamic block that is a call out bubble.  Just a circle with an editable letter or number inside.  I would like that block to function such that I can make the line coming off of it have an closed arrow, closed dot or nothing.  Id like it so that I can move the end of the line wherever I want it and the tail end always stays connected to the circle and points through the center.  I can create it myself but before I spend the time, I thought Id see if anybody already has one you can share or steer me towards.
Thanks in advance
Re: Call Out Bubble Dynamic Block
« Reply #1 on: September 25, 2019, 08:53:42 AM »
Have you looked through the dynamic block forum? There may be something that you can use.
http://www.theswamp.org/index.php?board=56.0
I've reached the age where the happy hour is a nap. ()
« Reply #2 on: September 25, 2019, 09:53:10 AM »
here is a starter and modify to your needs
« Reply #3 on: September 25, 2019, 10:44:15 AM »
You could also create an mleaderstyle that uses the attributed 'circle' block.
Windows 10 x64 - AutoCAD /C3D 2020
dtkell
« Reply #4 on: September 25, 2019, 11:13:24 AM »
The Annotation tab of the All Palettes Tool Palette may be a good place to start from.
\"What sane person could live in this world and not be crazy?\" -Ursula K. Le Guin
« Reply #5 on: September 25, 2019, 01:03:07 PM »
2nd that
The only reason I use the one attached earlier which mimics mleader is for callouts using sheetset manager otherwise I use mleaders
