Author Topic: points up in two list of points  (Read 2885 times)
dgpuertas
« on: September 24, 2019, 01:02:31 PM »
I have two list of points
I need to obtain another list with the points up include intersection.
Two lisp, one is natural terrain and the other is new terrain, and i need to obtain the final terrain.
in the image you can see more clearly what I need
Thanks a lot and sorry about my english
Dlanor
Re: points up in two list of points
« Reply #1 on: September 24, 2019, 08:05:11 PM »
How are you getting the lists?
If the lists were lwpolylines you could get a list of the intersection points between the two polylines using the intersectwith method. Then process each polyline drawing a vertical ray from each vertex and test if it intersects the other polyline. If it doesn't add that vertex to the intersection list. Repeat swapping the polylines should give you a list of all the upper points, then sort the list by the x-coord.
« Last Edit: September 24, 2019, 08:15:59 PM by Dlanor »
dgpuertas
« Reply #2 on: September 25, 2019, 04:04:54 AM »
There is not polylines its list of 2D points.
(setq ls1 (list (list 0. 34.)(list 40. 34.34)(list 50. 30.3).........)
and both begin in x= 0.0 ang finish in the same x numer.
I can create polylines but for time procesing i prefer not.
I ask for anyone have similar code to modify.
Thans Dlanor for your post
BIGAL
  • 40 + years of using Autocad
« Reply #3 on: September 25, 2019, 11:15:44 PM »
Creating plines then do something then erase them is not a problem using the built in intersectwith function saves programming look again at Dlanor idea.
This is civil design software solution have you looked at that ?
dgpuertas
« Reply #4 on: September 26, 2019, 04:19:53 AM »
I use AutoCAD only.
I know that Civil 3D or similar can do it (i hope) but I will use at 1% of possibilities and think that is a few use to buy the software.
I try do it by myself.
Thans a lot
Dlanor
« Reply #5 on: September 26, 2019, 05:50:27 AM »
How do you get the lists of 2D points? Do you write them using the keyboard? Are they imported from other software?
dgpuertas
« Reply #6 on: September 27, 2019, 03:44:09 AM »
-one list is the prolife of a line from one TIN (3dFace)
Thanks a lot YMG
http://www.theswamp.org/index.php?topic=9042.msg555712#msg555712
-the other list its calculate by another lisp that find terrain to aport.
dgpuertas
« Reply #7 on: October 02, 2019, 12:42:42 PM »
I finally did it.
And run with three parametres two list and a fun
fun is <  Find the point at bottom
fun is > Find the point at top
;(junta_lista_puntos_terreno_arriba_abajo (list (list 0 2) (list 5 2) (list 10 1) (list 20 3)) (list (list 0 3) (list 4 0) (list 11 2) (list 22 3.4)) <)
(defun junta_lista_puntos_terreno_arriba_abajo (listerr lisapp fun / list_inter ls1 ls2)
  (setq list_inter (apply (function append) (mapcar (function (lambda (p1 p2)
       (vl-remove nil (mapcar (function (lambda (p3 p4)
  (inters p1 p2 p3 p4))) lisapp (cdr lisapp))))) listerr (cdr listerr)))
ls1 (vl-remove nil (mapcar (function (lambda (p / y)
(if (setq y (BUSCA_Y_PERFIL (car p) lisapp))
    (if (fun (cadr p) y) p) p))) listerr))
ls2 (vl-remove nil (mapcar (function (lambda (p / y)
(if (setq y (BUSCA_Y_PERFIL (car p) listerr))
  (if (fun (cadr p) y) p) p))) lisapp))
  (vl-sort (append list_inter ls1 ls2) (function (lambda (a b) (< (car a) (car b)))))
roy_043
  • BricsCAD 18
« Reply #8 on: October 02, 2019, 01:38:07 PM »
Can't test the code because BUSCA_Y_PERFIL is missing.
It is a nice start, but just reading the code I believe it will only work in certain quite specific situations.
It will not handle the example in the image attached to your first post for example.
dgpuertas
« Reply #9 on: October 02, 2019, 04:50:35 PM »
works fine,
BuscaYperfil ->
find the cartesian y value with x position and a list of points.
linear interpolation between the point ahead and the behind
use another function like linear interpolation and find integer item inside a list of points
If you are interested i will post them
« Reply #10 on: October 02, 2019, 05:04:06 PM »
Any algorithm which involves sorting the points will fail for concave terrain, for example, consider the result you will obtain for the following two polylines when sorting by x-coordinate:
(entmake
        (0 . "LWPOLYLINE")
        (100 . "AcDbEntity")
        (100 . "AcDbPolyline")
        (90 . 10)
        (70 . 0)
        (10 0.0 0.0)
        (10 2.5 0.0)
        (10 1.5 0.5)
        (10 1.0 1.5)
        (10 1.5 2.5)
        (10 2.5 3.0)
        (10 3.5 2.5)
        (10 4.0 1.5)
        (10 3.5 0.5)
        (10 5.5 0.5)
(entmake
        (0 . "LWPOLYLINE")
        (90 . 4)
        (70 . 0)
        (10 0.0 0.5)
        (10 2.5 0.5)
        (10 3.5 1.0)
        (10 5.5 1.0)
The correct result would be:
(entmake
        (0 . "LWPOLYLINE")
        (90 . 9)
        (70 . 0)
        (43 . 0.1)
        (10 0.0 0.5)
        (10 1.5 0.5)
        (10 1.0 1.5)
        (10 1.5 2.5)
        (10 2.5 3.0)
        (10 3.5 2.5)
        (10 4.0 1.5)
        (10 3.75 1.0)
        (10 5.5 1.0)
But this cannot be achieved when sorting by either coordinate.
roy_043
  • BricsCAD 18
« Reply #11 on: October 02, 2019, 07:35:13 PM »
works fine,
My apologies, I see now that I have misread the code.
dgpuertas
« Reply #12 on: October 03, 2019, 02:49:03 PM »
Lee as usual is right
The point is that situation is not real because the TIN terrain never consider concave terrain. (in my opinion)
For me is correct and i use well.
roy_043, its not necesary apologies....
I rewrite because double if its not necesary.
(if (or (null (setq y (BUSCA_Y_PERFIL (car p) lisapp))) (fun (cadr p) y)) p)
    )) listerr))
(if (or (null (setq y (BUSCA_Y_PERFIL (car p) listerr))) (fun (cadr p) y)) p)
    )) lisapp))
